Palm Pre Cell Phone Logo
A
Anonymous Posted on May 17, 2010
Pre Cell Phone: how do i remove an application from my launcher?...
How do i remove an application from my launcher?
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jun 23, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
79
Points
Press and hold the red key on your key pad. Tap the ap and delete. Only the applications you installed can be removed.
I cant get in y phone. all it says is launcher stopped working. what can I do
Reboot. Remove battery and wait for 5 seconds. Put it back on. Enter 'Recovery Mode'. There will be some hardware button combination to enter Recovery Mode like Power+Volume Up+Volume Down. After entering, depending on your phone, you might have to navigate through physical buttons.
You will find 'Clear Cache' and 'Clear Dalvik Cache'. Do both.
And then Reboot normally. Now see if you can get the launcher working on your phone.
If that doesn't work, press home key, see if you can open some browser application or Play Store and download and install a new Launcher.
If that doesn't work, but you can somehow access settings, go to settings->Apps and clear data of your Launcher App.
If that isn't possible then, go to Recover Mode again and do 'Reset Factory Defaults'. This should make your phone feel just like when you brought it.
May 19, 2016 • ZTE Warp
tip
How to Install ADW Launcher on an Android Phone
<p>ADW Launcher is an Opensource home/phone desktop replacement application. Meanwhile, the EX Launch ADW is highly customizable home replacement applications that require you to buy it for use. It also set your desktop android. It is an Android application that normally runs when you press the HOME button phone android. It is usually what people know as the "android desktop". <br /> <p> <br /> <p>To download the ADW Launcher go to Android Market, try these steps: <br /> <p><span> </span>1. Android Market to open in your phone and go to "Search". <br /> <p><br /> <p><span> </span>2. Type "ADWLauncher EX" in the search field and "Search" from the press. <br /> <p><br /> <p><span> </span>3. Once you have the "EX ADWLauncher" game, choose "Install" and follow the instructions. <br /> <p><br /> <p>EX ADW.Launcher <span> </span>ADWLauncher is based on core opensource with a series of improvements and new features, as follows - <br /> <p><span> </span>1. 5 different styles tray app / behavior <br /> <p><br /> <p><span> </span>2. Several transitions desktop, new animations while browsing your screen. Try them all. <br /> <p><br /> <p><span> </span>3. New icons settings / look and feel: Tweak desktop icons; change the size funds, to add color, change font, color, etc. <br /> <p><br /> <p><span> </span>4. Presets new speed so fast the entire desktop configuration by one click. <br /> <p><br /> <p><span> </span>5. Editable desktop application icons, shortcuts and folders. <br />
on Aug 18, 2011 • Google Android
My phone has stop working all gmail,dialer,everything
Are you using a launcher you downloaded? If so, it may be that it is having issues and not opening all your applications. To fix this you can revert to the default launcher by going into settings, finding the name of the launcher that isn't working and pressing "Clear Defaults", when you press the home button, make sure to choose the default launcher and then try to use your apps again.
Jan 10, 2016 • Cell Phones
How to remove touchwiz home on note 4
I don't think you can do that because it is the Samsung built-in/default launcher and it comes pre-loaded with your tablet. If you don't like it (I assume that's why you would want to get rid of it), install other app launchers, such as Apex Launcher, Nova Launcher, etc. from the Play Store and use any of those as your app launcher.
2answers
My phone has no launcher
Hey Speedy Aristotle the UI you have is it self a launcher. But you can download various launchers from google play store like GO launcher that is free but you can have paid application too. This is only for the Android phones.
Please write a good description about your problem so that I can have better understanding about your problem.
Apr 15, 2014 • Cell Phones
I wont to reset my palm my phone
A Hard Reset (Full Erase) will erase installed applications, application settings and data.
  1. From the Home screen, touch the launcher icon.
  2. Touch Device Info > Reset Options > Full Erase > Full Erase.
Steps to Perform Remote Hard Reset
This can be performed from your Palm profile online.
  1. On your computer, go to palm.com/support
  2. Enter your Palm profile email address and password.
  3. Click Wipe Device to remotely reset your phone.
http://www.resetcellphone.com/solution/Palm/pre
8helpful
2answers
No anti virus and themes support my s5620 monte.please tell me the answer how i get it.
Cellular device viruses are very rare. Should you find an 'anti-virus' in a marketplace, I would simply avoid them. They are not necessary and many of them will populate with false alarms requesting you spend money to protect your device.
As for themes, your phone is equipped with Samsung's TouchWiz user interface. You can move your icons and applications around, and you may change your background, but other than that your customization options are limited.
You may try and disable TouchWiz for a different look by going to Settings, then Applications, select the Running Applications option and find TWLauncher and force close it. This is supposed to send the phone back to the stock Android launcher; On some devices TouchWiz will restart immediately with no visible effect. Stopping this process will not cause damage to your phone, nor should it cause a malfunction of any sort.
You can also check the marketplace for Launchers, such as ADW Launcher, which is much more customizable than TouchWiz.
How can i remove the voicemail icon from Samsung GT-C6112. Thanks
This phone is running android 2.2 im assuming. The voicemall Icon can be romoved from your home screens by long pressing on it and moving it to the trash area depending on the launcher. If you are trying to remove the app itself this is not possible unless the phone is rooted. Im not sure if this is advisable though. If your phone is rooted a safer measure might be to use bloat freeze to freeze the application so it never runs. Or root uninstaller will allow you to remove the app all together. hope this helps kidromulous
1helpful
I want to set a theme for my lg optimus and I dont know how to can you please help me
The easiest way to change the theme or look of the LG Optimus (or any Android phone for that matter) is to download a new launcher. The Launcher is like the desktop for Android, where you can place widgets and app icons. There are different Launcher's available to download from the Android Market, and some of them can be themed and dramatically change the look of your phone. There are multiple good ones that can be themed. Just go to the Android Market, search for ADW, OpenHome, GO Launcher EX, just to name a few that can be themed.
Once you install the new Launcher, when you hit "home" it will bring up options to choose which Launcher you want to use. Don't select "use as default" until you're sure you want to settle with one of them. (*if you do select use as default, and then want to change again, see the note at the end of this)
If you go back to the Android market, and search for ADW themes, OpenHome themes, etc., you should see quite a long list of various themes for each launcher. Install one you want to try, then hit home. You'll need to apply the theme in the Launcher's settings, which is normally accessed by (from the home screen) hitting the menu button, and then "preferences" or "adw settings" (if you're using ADW). From there, depending on the Launcher you're using, find the section that has to do with "Themes" or "UI". From there, you should be able to select and apply the theme you just downloaded and installed. It can't hurt to download a few if you want to test a few.
Changing Launchers is a great way to change the look and feel of you're phone, as a lot of them run much smoother than the Launcher that comes default on the phone.
*If you set a Launcher as default, but want to change it... the easiest option is to download "Home Switcher for Froyo" from the Android Market, and use that to change between Launchers. The longer was is to go into Settings -> Applications -> Manage Applications, find the Launcher you're using, click on it, and select "clear defaults". Then when you hit the "home" button, it should bring up your options again.
2helpful
2answers
How do I remove apps from the screen and phone?
Click setting, then applications, then manage applications. You will be able to remove the apps from there.
Top Palm Cell Phones Experts
ExpressFiX
ExpressFiX
Mohammad Abumuailek
Mohammad Abumuailek
Are you a Palm Cell Phone Expert? Answer questions, earn points and help others
