You can get most Hoover manuals at the link below. You will just need your model number.
http://www.hoover.com/CustomerService/Manuals/Default.aspx
SOURCE: Floormate H3000 Upright Wet/Dry Vacuum: i need operation instructions for hoover H3000 flo...
You can download your complete manual by following the link below.
http://www.hoover.com/pdfs/manuals/H3000.pdf
SOURCE: need instructions for operation
The last time I checked, manuals were available on www.hoover.com.
SOURCE: Floor Mate
There is a black shaft with a black circular arm at a right angle to the shaft. The black plastic arm that sticks out of the front ( farthest away from the hinge) of the roller assembly plugs into the circular arm so that moving the scrub/vacuum slider causes the roller assembly to move up and down. I can do it with my finger, or use a flat blade screwdriver. I'm assuming you mean the black plastic thing with the little rollers on it.
Kirk Thompson
San Juan, PR
SOURCE: I lost the instruction manual for Hoover Floormate
The instruction manuals are found on the Hoover web site hoover.com
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
SOURCE: my hoover floormate will not dispense water
make sure check valve in the solution tank moves up freely. check that the sprayer tips are not cloged.
