Pride Jazzy Select 6 Indoor Power Wheelchair Logo
A
Anonymous Posted on May 17, 2010
Jazzy Select 6 Indoor Power Wheelchair: Hi! I just inherited a used Pride Mobility Ja...
Hi! i just inherited a used Pride Mobility Jazzy Select 6 power wheelchair. But I don't see the jack to plug in the charger. at the Pride Mobility website I tried to download the manual but their site just choked. can you please help me? Thank you! gerald
David Moore
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Aug 08, 2015
David Moore
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
749
Points
6
Did you find the plug in as of Aug 8th ? the plug for the charger is on the bottom side of the joystick controller, a 3-pin Plug-in.
Anonymous
Level 1:
New Friend:
  • Posted on May 20, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
749
Points
There should be a place to plug the charger in on the front of the joystick. It is a round three pin connector
Jazzy Select 6, turns on, when joystick is moved, it stops and blinks 9 times.
Question edited for clarity.
Question moved form Car Audio to Pride Jazzy Select 6.
9 Flashes The park brakes have a bad connection. Check the left and right motor connections and wiring. Check to make sure that the power chair is not in freewheel mode.
jazzy select - Any electromechanical device requires ...
Videos as well
https://www.google.com/search?q=jazzy+select+6+blinks+9+times&
How to stop squeaky wheels
My tires squeak how can i fix the problem and what ... - Fixya
www.fixya.com > ... > Pride > Jazzy Select 6 Indoor Power Wheelchair
Apr 14, 2012 - my tires squeak how can i fix the problem and what can i use - PrideJazzy ... Question about Pride Jazzy Select 6 Indoor Power Wheelchair ... I have a mpv 5 hoveround wheel chair and I now have a flat on the front left tire.
[PDF]Jazzy Select Series Owners Manual - Pride Mobility Products
www.pridemobility.com/...jazzy/us_select_series_om.pdf
Pride MobilityJazzy Select 6 with Power Seat. JAZZY. SELECT SERIES. Including Models: Jazzy Select, Jazzy Select 6, and .... Battery charger for indoor use only. .... Take wide swings with your power chair's front wheels around any tight corners. ... desired, allow it to come to a complete stop by releasing the joystick, then push the ...
[PDF]Jazzy Select Series - Pride Mobility Products
My Dad's 2012 Pride Jazzy Select 6 wheelchair is difficult to maneuver. Since all 4 wheels rotate, backing up straight is impossible. What is my problem?
A light touch on the joystick is first. If it remains difficult then have the joystick reprogrammed. Only a dealer is set up to reprogram a joy stick.
How do i fix the chair when the control flashes 9 times
Typically when a joystick flashes 9 times, it indicates there is a problem with the solenoid brake(s). I recommend contacting Pride Mobility for a Certified Technician in your area to look at this chair.
Where is the best place to by part for jazzy chair
READY MEDICAL & MOBILITY in Carencro, Louisiana 70520 - 337-565-6784.
2helpful
2answers
I have a Jazzy 1121 wheelchair and need a face plate for the controller. The ss# is J40355044020. Where can I find one?
Contact Pride Mobility @ 1800-800-8586 ask for Jazzy tech support and ask if you can order a faceplate for your joystick Hope this helps you
What kind of Jazzy select 6 power chair does my Mom have? Serial number J92037090688C30. We live far away from each other and I need to know what she got.
Here's a link to Pride Mobility, maker of the Jazzy wheelchairs. This takes you to the Select 6; there's also a Select 6 Ultra. Just click on models and it will display all of their line of equipment.
Top Pride Health & Beauty Experts
Rob Hill
Rob Hill
Mike Cairns
Mike Cairns
Grand Canyon Tech
Grand Canyon Tech
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
