I have a L shape wire left over on reassemble of my handle on my upright oreck. One end hooks into a hole on the handle shaft where does the other end go?
Doc
Place handle half with the posts that hold the screws facing up.
silver pole with hole that goes completely throuigh goes over lower screw post (Long side)
static wire - L shaped end goes in small hole on opposite side of handle just below
vacuum switch hole, curve of wire should follow curve of handle and fits into top of
silver pole and pushes againt it providing push to hold siver pole.
hope this helps
Reassemble of handle on upright
Oreck XL 2200 Bagged Upright Vacuum
I have a L shape wire left over on reassemble of my handle on my upright Oreck. One end hooks into a hole on the handle shaft where does the other end go?
Doc
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
I suggest that the upper handle for the Oreck XL2200 should just be help on by sliding the handle over the upper handle assm and there is one screw that you use to tighten the hand e to the upper section, the lower handle assm just slides in to the lower motor assm handle and so does the top. I was not aware of any wire for the handle assm. Feel free to contact the Oreck Corp factory phone number listed below or call your local vacuum dealer in the yellow pages.
http://www.oreck.com Customer Service
Customer Service Hours:
Monday - Friday
7am - 7pm Central Time
Saturday
8am - 4:30pm Central Time
Sunday
Same thing here, opened up the handle to splice together a cut wire and the odd spring mechanism consisting of a somewhat "U" shaped wire that is bent differently on either end. I did see that orginally it was through the hole at the top of the shaft part of the handle.
Replaced on/off switch but handle won't stay on the shaft. There are no screws that go through the handle & the shaft to hold it on. Am I missing a piece or just doing something wrong? My wife took the handle off while I was at work so I don't know how she got it off.
