When I turn the dial to start wash cycle nothing happens. The red light comes on if I turn to a 'soak" cycle so the power is on but no water enters the machine and no action happens. Worked fine on the last load completed full cycle but on the next load nothing. Power is on but no action happens.
SOURCE: Drum Does Not Spin
We had the same problem on a 7-yr. old WFK02401 washer that had been used daily for 7 years. Bosch's approved repair people quoted us $350 for installing a new motor. In fact, all it needed - knock wood - was new motor brushes, for which I paid all of $45, including shipping (or cheaper, if I'd ordered directly from Bosch.) To replace these requires a half-inch wrench and a bit of confidence and common sense. I won't go into all the details, here, except to say that you need to remove just two bolts, unattach the bundle of wires strapped to the motor housing, take out the motor, replace the brushes, and put back the motor. There may be a problem with one of the control modules in the machine - electronics that oversee the washing cycle and turn the motor and other items on and off during same - in which case you may want to find a repair person. I just learned that there is a circuit diagram pasted under the machine's top cover; it includes some resistance values (ohms) that can help with troubleshooting, I believe. Bosch's own repair/service people - third-parties, all of them - are not going to want to replace brushes; they make more money doing entire motors, I imagine. Also, they do not like it when a man watches them work or worse, when a woman (aka my wife) asks them smart questions. They are used to having their way with slightly intimidated and ignorant females - trust us, and pay us. But that's another story.
SOURCE: WASHER WONT START
The fuse is usually mounted on the control board when power connection comes to the board.
SOURCE: GE front load washer
Remove the front lower panel (3 screws on lower lip - lay on floor to see). Panel come right off. there is a round "dial" to the front housing. Put down a bath towel on the floor and unscrew dial - then pull it out.
SOURCE: maytag mav7000aww washing machine doesn't work
Ok, I figured it out, at least my problem. The short answer is that you need to replace the lid switch assembly, maytag mav7000aww part no. 12001908.
To verify you have the same problem as I do, remove the rear cover to the control panel (three philips head screws and two machine bolts, see http://www.partselect.com/ModelFrames.aspx?ModelID=117917&ModelNum=MAV7000AWW&mfgModelNum=&ManufactureID=1&Selected=52442&Position=2&mfg=Maytag&Type=&Mark=2 no. 14.) Use a volt meter to verify that you have power coming into the lid switch assembly harness (black wire). Use the volt meter to verify that you have no power coming out of the lid switch assembly harness (red and yellow wires.)
To further verify that you have the same problem as I do, remove the wire harness from the lid switch assembly and use a ohm meter to verify that the switch is not allowing power transmission. In the lid closed position (lid switch depressed), use ohm meter to test line-to-motor and line-to-machine connections.
If you verify that you have no power down-circuit of the lid switch assembly using the two methods above, then you have my problem. In this case, you can purchase the part noted at top for less than $25.
SOURCE: maytag washer won't fill or agitate; only spins on cycle
sounds like you have a blown fuse. I dont have a schematic so I dont kno where you have to look to find it
