HP Compaq Presario V5207NR Notebook Logo
A
Anonymous Posted on Feb 21, 2018
Compaq Presario V5207NR (EZ430UAABA) PC Notebook: I have a compaq presario v5207nr and have recently...
I have a compaq presario v5207nr and have recently added skype software and software for a microsoft lifecam. Then when I tried to start it up it just runs and runs and doesn't get to users page to choose "log on as". Have run a hard disk test and it came back with 07 Fail. What can I do
Larry Ng
Level 3:
Top Expert:
  • HP Master 14,585 Answers
  • Posted on Feb 21, 2018
Larry Ng
HP Master
Level 3:
Top Expert:
Answers
14585
Questions
0
Helped
3276856
Points
66542
Old compaq, with full service tag data wow./! 13 years old now.
XP right? 2001 to 2007, your PC did not have vista. new.
XP is dead, did you know that?
then you fail to tell what OS is running,
guess what that matters, (we know what it was new but....)
if it's XP and or vista is does, XP is dead now for 4 years.+
and worse IE is even more dead, and now banned on many web sites and is an expanding *****.
did you go to MX owned skype home page and read the minimum requirement there, first?
there are 3 issues here.
  1. XP is dead.
  2. your XP microphone be died
  3. your XP webcam is dead, all very normal now.
here is what skype said, believe it.
https://support.skype.com/en/faq/FA10328/what-are-the-system-requirements-for-skype
as you can see new skype is dead for XP
XP is a virus magnet as is its unsupported IE versions, (all)
note the tight restrictions on w10, wow.
Compaq Presario V5207NR (EZ430UAABA) PC Notebook:  - min-izjzmxrsoyt0tzrru5htkmqj-2-0.jpg
  • Anonymous Feb 21, 2018
    the answer is UPGRADE
    there is no other way. w7 can be bought and loaded, but that costs $120
    then you find out many devices in the laptop
    called CHIPS,(sound,NIC, video,camera,etc)
    are missing drivers or worse, never made for W7. we can find most but not all.
    better is go to the used PC store.
    even GOODWILL, find a working PC , (any) that has working w7 on it or newer.
    be best, cost wise. (and x10 better support)
5 Related Answers
Anonymous
  • 1142 Answers
  • Posted on Jul 02, 2008
SOURCE: HP Compaq Presario V3000 PC Notebook - Screen Blank, Won't Boot
Check with www.hp.com
Anonymous
  • 186 Answers
  • Posted on Oct 18, 2008
SOURCE: compaq presario v3000 laptop..doesnt recongize the hard drive
I beleive that you are trying to install retail versions of XP which will not be able to detect the Hard Drive in the Notebook as it is a SATA drive and Windows XP will not be having the drivers for SATA Hard Drives by default.
In this situation, I recommend you to check and disable the SATA Native support  option available in the BIOS.
Start the Notebook and start tapping the F10 key which will take you to to the BIOS Setup window.
In this, go to the System Configuration tab using the Arrow keys and select the option as Disabled next to SATA Native Support.
Press the F10 key again to save the settings done and exit BIOS.
Now, you should be able to use the Windows XP disk and install Windows XP Operating System in your Notebook without any issues.
By disabling the SATA Native Feature, the Hard Drive of the Notebook will be detected as a IDE Drive because of which we will be able to install XP without any issues.
Donot Re-Enable this feature in the BIOS again as the Operating System may not boot. Let the option next to SATA Native Support be Disabled.
Hope this helps...
leecom72
Lee Hodgson
  • 4810 Answers
  • Posted on Apr 06, 2009
SOURCE: won't boot up, Hard drive self test result #1-07 Fail
Hi there.
The hard drive has failed and you will need to replace it.
If the laptop is under a year old take advantage of the warranty and send it in to be repaired for free.
Good luck and thanks for using FixYa!!
herseytone
  • 84 Answers
  • Posted on Mar 21, 2010
SOURCE: running home ed windows on presario v2000 (now
Backup your programs immediately to a thumb drive or external HD. The hard drive may be on the brink of failing. You can replace a hard drive, it's your information thats on it that you may not be able to if it totally crashes!
Anonymous
  • 382 Answers
  • Posted on Sep 09, 2011
SOURCE: Compaq Presario CQ61-313US Notebook PC won't power
try to remove first your battery and use only the adapter.
How can I fix starting and stoping when watching streaming videosI have a gateway LT2805u.
You could try codecs (K-Lite free!), or maybe even a different browser. May even be network speed (buffer). Play the video, but pause till it loads, then play.
I cannot open the mms in my phone
That has to be a configuration problem. you need to request for configuration settings from your service provider. when the settings is sent and you install it, you start browsing again. thanks
GRAPHIC PROBLEM & VIDEO IS NOT WORKING SOUND & PICTURE
If you have reinstalled Windows then you need to install the Presario device drivers.
You can download the device drivers from the Compaq/HP WEBsupport/download page. Make sure
you select your model laptop and the Windowsdrivers you require and install them. Click on this link to download thedrivers: -
www.compaq.com/country/cpq_support.html
Went to hibernaye on it's by itself will not come back up
Some laptops/Notebooks automatically go to sleep/hibernate when their power level gets too low. Try plugging in an adapter then pressing the power button again while it's plugged in.
Rate if this helps
I want to have my sound driver to be instal
If you were to log on to the manufacturer's web site, I think you will be pleasantly surprised as usually one is able to download, by model number, Customer Instruction Manuals, list of Dealers for spare part supplies and Driver downloads (if applicable) as required.
Just Google the manufacturer's name and follow the links. Make certain you are directed to the manufacturer's web site as some search engines direct you to other sites and they charge for the information that is normally free of charge.
I hope this helps.
Compaq presario V5207NR sound drivers
If you have installed Windows Vista for the first time, you need to download the drivers for the same. Go to www.hp.com and click drivers and downloads. Select the computer model and operating system and download the sound driver.
Thanks
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
