No
one give you the code for free. If anyone does so it`s harmful for your handset because if the code
doesn`t works than your handset become hard lock & the Charges of Unlocking a
Hardlock
set is normally 60$ to 90$ in the market. So don`t believe anyone and
get a mep code from a verified provider in just 10$ to 15$ Now. There are many ways to get Blackberry Mep Code. As far as i concerned the best way is to get mep code from an Online Blackberry Mep Code Provider (through a Website). The Website will give you the mep code as cheaper, as well as much faster (within 1 minute) than a seller does. Website also gives you a 100% money back guarantee if the code does not work. This is the best way to
get mep code for your blackberry & unlock it from the comfort of your home. Unlocking through code is permanent means it cannot be re lock again itself!!! Click here to get blackberry mep code
Hello,go to this link, and follow their direction to get your mep code. Usually mep code is needed when you want to unlock blackberry pearl 8100 network, however if you want simple way to unlock your phone network try to use blackberry unlock code.
Hello.
You can get MEP Code for your Blackberry from official Blackberry unlock code provider.
I hope this provider helps you a lotto solve your problem.
Click Here
Thanks
SOURCE: hi!i have bb pearl 8100 but how ill get it mep code for free
Some carriers will just give you the code, some give unlock codes and some don't give the codes at all. If you can't get the code from your carrier you can buy it online. There are tons of websites offering codes but I have no idea which are trustworthy and which are not.
SOURCE: i need a code to unlock my blackberry pearl 8100
Please contact your service provider to get the unlock key from where you purchased this handset. After unlocking you use service from some other operator
SOURCE: i nedd the mep number for my blackberry
Blackberry can be unlock eaisly with remote unlocking codes. you can get this Blackberry imei unlock code from your network provider or get from third party,
both are safe way to Unlock your Blackberry Pearl 8100.when you go to online you can find so many sites of Blackberry imei Unlock Code. they will charge little amount for your Blackberry Unlocking Codes. i hope this will help you:)
Best of Luck.
