KitchenAid KESC307 Electric Kitchen Range Logo
Posted on Apr 02, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Kitchen aid single electric oven
I used the cleaning fixture yesterday am. went to cook something in the pm and the oven will not heat up it says LO
Ron Coons
Level 3:
President:
  • KitchenAid Master 2,651 Answers
  • Posted on Apr 03, 2008
Ron Coons
KitchenAid Master
Level 3:
President:
Answers
2651
Questions
Helped
1546785
Points
7824
Soundsl ike youve blown a thermostat on the back wall of the unit(fairly common with the K/A appliance, unit wikk have ot be pulled out to check continuity on the thermosts( loactated behind back wall just between the broil element hook ups.
I have a Kitchen Aid model kebc177kss04. After using the self cleaning feature the oven fails to heat up. Everything appears to be working. The LED display says temp is Lo when the fan is on and no heat...
This happened to me three times with a brand new oven, they kept coming back and replacing the fuse. I finally made the Kitchenaid dealer replace the whole oven, never happened again.
Excessive smoke comes out from oven when cooking
hmmm sounds a bit strange is there anything at the bottom of your oven that has been spilled on it even on the heating coils? (if electric) (if gas there could be a very serious problem with the oven that needs fixing right away!)
I have a Kitchen Aid Surpurba 1999 built in oven.
on the back of oven there is a hi limit thermal fuse /it is a one time fuse /eplace it cost about 23. to28 .00 . / you willhave to remove oven from wall ( two are best .. set it on a small table /cable may be short.. hope this helped /pls leave feed back ..
Dec 06, 2009 • Ovens
I used the cleaning feature on my kitchen aid architect series oven KEBK101 - now when you turn the oven on it does not heat up - what part do I need to replace - Kitchenaid will not address
Yup Thermofuse stops the elements from heating after the self-cleaning cycle. You have to take out the oven, TURN OFF THE POWER at your circuit breaker, remove all the screws on the oven back panel, you'll see the thermofuse near the center (there are two 1/4" spade connectors (one leads from one leg of the power junction box). Two screws to remove it.
My oven will not heat up at all.
make sure your cooking timer is on manual....
Wall oven controls do not light-up or function.
i cant call you but iv seen this a few times the display part of the board went out (you can still probably get it to cook but cant see the temperature) you are gonna have to replace the board.
14helpful
2answers
Kitchen aid oven not heating up
THERE IS OVENSHUTDOWN THERMAL FUSE IN THE BACK THAT WILL SHUT DOWN THE ELEMENTS. I AM LOOKING FOR THE FUSE.
Kitchen aid kebc278 dual ovens don't work
yes once of the door switches is broken you could jump out the switch
Self Clean does not work
Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
Top KitchenAid Kitchen Ranges Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
vince
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
