Please check that the power connection - to the outlet and to the device itself is as it should be.
Mostly, when these things occur, it's related to a physical problem - either with the power source (cable/outlet) or a physical problem with the drive itself.
The Western Digital Scorpio Blue 500GB hard drive is formatted for PC, not Mac. The simplest way to get your MacBook to recognize this new drive--and therefore copy the files from your old drive--is to plug it in to a PC and format the drive. I was advised to format with FAT 16, as this would be recognized by my MacBook. Fortunately, the process was not that involved, since the Vista-driven PC found the drivers for the WD Scorpio Blue automatically. Once formatted, I safely removed the drive and plugged it into my MacBook via a USB port using a BYTECC Drive Mate. Magically, it now appeared on my MacBook Desktop and was recognized by the cloning software I was using, SuperDuper. Three hours later, the files on my old hard drive were successfully cloned onto the Scorpio Blue--except now I had an additional 364GB of storage space. Swapping out the old drive and replacing it with the new was not a big deal at all--just make sure you have the right screwdriver for the last task--a Torx #6. Mission accomplished.
The SATA Drives do not need jumpers to set primary and secondary drive positions. Each sata drive gets it's own connection to the motherboard. Check you motherboard diagram, and make sure the 320GB drive is plugged into the 1st sata controler, and that the 500GB drive is connected to the 2nd.
Dear Sir,kindly note this problem usually caused by a firmware damage,so you need find a dr company to use tool to repair the firmware,you can contact with me :[email protected]
Hi there No there is no need to change any jumpers on a sata drive, go into the bios settings and tell the bios to boot from the western digital drive only.
This laptop uses a SATA hard drive. From what I see the max on those is 500gb. If I was to make a recommendation, Western Digital Scorpio Blue WD5000BEVT 500GB 5400 RPM 8MB Cache SATA Notebook Hard Drive $107.
Try reseating the power connector for the drive. You can try another unused connector if it will reach. Do the same for the data cable. Reseat both ends of the cable a couple of times to shine up the contacts. If none of this works, then a data recovery service will be needed.
