Hitachi C10FSB 10" Sliding Dual Compound Miter Saw Logo
A
Anonymous Posted on May 17, 2010
C10FSB 10" Sliding Dual Compound Miter Saw: how to repair brake...
How to repair brake
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Sep 14, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1664
Points
Replace the Stator!
Power Glide 8.25 (in.) miter saw with laser guide, model 60201002. What is bolt size?
You take out your AF and Metric socket set and it is the one that fits.
If you are asking because you need one, you go to a spares outlet. Or you can take the saw down to Home Depot.
Ryobi Miter Saw Parts ' Fast Shipping ' eReplacementParts.com
https://www.ereplacementparts.com > ryobi-miter-saw-p...
Ryobi Miter Saw parts that fit, straight from the manufacturer. Use our interactive ... This is an OEM Authorized replacement part used on variety of power tools. Ball Bearing ... MS181 Ryobi 8.25" 18V Cordless Compound Miter Saw Parts. P3650 Ryobi 10-Inch Sliding Compound Miter Saw With Laser Parts. P550 Ryobi 8 ...
Miter Saw Parts ' Tool Parts Direct
https://www.toolpartsdirect.com > saw > miter-saw
Tool Parts Direct sells miter saw parts for nearly 400 models of miter saws. Browse by ... Parts List · 10" DUAL SLIDE COMPOUND MITER SAW WITH LASER ...
May 05, 2021 • Saws
Can't lock miter angle with slide handle
There is a plate under the turntable which needs to be replaced, remove centre bolt locknuts and washer (44,45 and 46) from the underside of the base and lift the turntable off taking care to not loose the detent spring (36) and steel ball (37), turn it upside down and remove the spacer plate (31) and replace it, use a small amount of grease on the spring and steel ball during assembly to keep them in place
I have a Malita dual sliding compound miter saw LS1016LX. Trigger will not start saw after 5-10 cuts. When saw sits for 30 minutes, it runs again.
I'd contact a Makita dealer. I've had this saw for years without a single misfire on the trigger. Could be heat related, but that's a stretch. Here's their contact information:
Makita Contact Us
I have the old model c10fsb mitre saw but need to replace the two parts of the handle & the trigger,where would i get them ?
You can go to www.toolpartsdirect.com and search by brand name than tool description by model number then view a schematic to get part numbers. You can also call direct at 1-866-597-3850.I hope this helps you. Good luck and thank you.
Bosch gsm 10 compound mitre saw. which way does the screw turn to undo blade
On the Bosch compound sliding miter saw, turn the blade nut clockwise to remove it.
I’m happy to assist further over the phone at https://www.6ya.com/expert/bill_f6ca18ca1db028ed
2helpful
My saw is really stiff when you try to change the angle .I oiled it but this didn't help. I would like to know how to take it apart but I am un sure how to do it and what is in the boxed off area...
Exploded diagram with parts list for LS1016 10" Dual Slide Compound miter saw is here.
Owner's manual is here. If these aren't quite what you need, you can view other models of Makita miter saws, here.
One thing to bear in mind. There's a miter angle lock and a slide lock on the bottom front of the saw. If you don't have the miter angle lock loose enough, it will be difficult to turn the saw.
If this answer was useful, please vote for it. Thanks!
I borrowed a chop saw and it is in lock position, how do i release it
on the back of the saw where the arm goes up and down there is a pin that pushes in it will only stick out about a 1/2 inch.
Need wiring diagram for the box on the outside of the motor.
white from cord to B. grey from stator to A. blue from brush holder and red from switch to C!
3helpful
Craftsman 10-in. sliding compound miter saw
there should be a safety latch on the right ..down by the base or at the back you should have to press down on the saw to release it.hope that helps..
Top Hitachi Saws Experts
Mike Cairns
Mike Cairns
Steve Pack
Steve Pack
john h
Are you a Hitachi Saw Expert? Answer questions, earn points and help others
