Fisher Price Power Wheels Kawasaki KFX Ninja Ride-On Toy Logo
Anonymous Posted on May 19, 2010
Barbie jeep won't go forward.
My daughter has the Barbie jeep.The prob we have is that it won't go forward but will reverse when the reverse gear is selected...any help would be appreciated greatly!!
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Oct 08, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1842
Points
5
I think you need to unscrew or pop out the switch where you select forward, reverse, etc. Then clean off any metal parts and reconnect. I had the same problem and this worked for me on a different model (Powerwheels Ninja).
I have lost forward gears on Jeep Grand 2.7CDR taking only in reverse
the transmission computer computer has gone into fail safe mode
an electronic failure not a mechanical failure
could be something simple as a computer re-set or
a transmission solenoid s
will need a jeep service center
or automatic transmission work shop to fix it
My granddaughter's barbie cruisin' tunes jeep only has fast gear, no slow or reverse.
check and see if both wheels are spinning, if not you have a bad motor which would cause the other gears to not work
Forward and reverse switch wont work on my barbie speedy car
make sure that you're using the switch located on the floor and not the one on the dash, if you are than i can get you a replacement, they are really easy to replace also
May 23, 2012 • Toys
My daughter's barbie power wheel jeep keeps slipping out of gear and won't drive.
make sure that the cogs on the tires are in tight contact with the drive motor, you might have to add some washers to take up the free space
1helpful
My son ford f150 truck want go forward and my daughters want move and all and both batteries were charged for two days straight.
my son's does the same. It will go in reverse but not forward. sometimes if I shift it repeatedly it goes forward for a little while. the shifter feels kind of loose. have you tried replacing it? i found a website that sells them. I think I need to replace it & see if it fixes it.
http://www.householdappliance.com/power_wheels_shifters.html
Top Fisher Price Toys Experts
ADMIN Andrew
ADMIN Andrew
Jennifer Rock
Jennifer Rock
NOEL
NOEL
Are you a Fisher Price Toy Expert? Answer questions, earn points and help others
