Car Audio & Video Logo
Posted on Apr 01, 2008
2004 mercury mountaineer door ajar light
The 2004 mercury mountaineer that i own is giving me trouble with the door ajar dash light staying on. All doors are shut properly but the interior lights stay on unless i turn them off manually and the alarm will not turn on as well.
  • 6 more comments
  • noah421 Jun 06, 2008
    I am having a similar problem in my '03. Seems like people are suggesting WD-40 in the latches to loosen up any sticking.
  • sjsears Oct 23, 2008
    Same problem here - 2005 Mercury Mountaineer.  Also when I have my interior lights manually turned off - when I push the rear defrost, my door ajar alarm goes off.  HELP!
  • ConHuskerFAN Nov 17, 2008
    Same problem here with a 2003 Mountainerr
  • Anonymous Dec 18, 2008
    I have a 2003 Mercury Mountaineer, seems like it slowly started happening, out of nowhere the door ajar light would come on, then eventually the dome lights would stay on when I would leave the car and I'd have to jump it. Now I manually turn the lights off with the interior switch every time I leave the car. Now when I hit the rear defrost the door ajar light comes on too.
  • danjones68 Jan 16, 2009
    Same Problem 2003 explorer door ajar light is off. I have to manually turn the interior lights off (Panel). Turn the rear defrost on and the door ajar light comes on. I have tried spraying the door latches and it did fix the door ajar light from coming on but the interier light will stay on unless the manual panel switch is tured off.
  • mmann719 Feb 10, 2009
    Same problem on my 2004 Mountaineer. Tried WD-40 on the latches, and that didn't work.
  • Anonymous Mar 02, 2009
    Have the same on my 2003 Mountaineer. Rear defrost turns on door ajar. Have to manually turn off dimmer or dome lights stays on-also auto lock says door is open(honk-honk).
  • Anonymous Apr 03, 2009
    I have the same problem with my 2004 Mountaineer. If I turn on the interior lights the door ajar comes on and if I turn off the interior lights by using the panel I can lock my doors properly. I have lubricated the latches on the door and is still experincing this problem.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Mar 08, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
5488
Points
7
Ends up being a broken wire(ground) in the rubber boot between door and frame. I carefullly removed door panel, pinched the ends of the boot and slid it back into door. And there it was...a broken black wire. Spliced in a new piece of wire, reassembled everything else. Everything works like it should. It's really not that hard just take your time. Also before I started I disconnected the battery as a precaution. Goodluck.
  • Anonymous Jan 21, 2012
    We bought a 2004 in Austin. It has been a remarkable vehicle. Im sure the next baby will be what ever u need in America Suv. Gas is decent , comfort , and performance. Im not a look person. But this light problem has been going on four a month . Now Thanks for the help I bought a new battery. Cause the battery was being drained. With a 30 minute light on dujring a wedding last month. We had took 15 min to charge battery then we got it crunkkkkkk. Peace
Anonymous
Level 1:
  • Contributor 27 Answers
  • Posted on Dec 18, 2008
Anonymous
Contributor
Level 1:
Answers
27
Questions
0
Helped
26161
Points
50
Could be a sticking latch, a short in one of the door latches, a problem with the dome light circuit itself, or a short in one of the wires. Look under the door seals and see if any wires have been caught or screwed through. Put some lubricant on the door latches. Last resort, start taking the doors apart 1 by 1 and disconnecting the door triggers in the latches. When you get the right door disconnecting it will make the other doors work right. Then you can replace only that 1 door latch. Otherwise you can just start replacing door latches till you hit the right one. If its in the dome light circuit there is a Black/lt blue wire in the driver kick panel in a harness to the rear. This wire shows + when the dome light is on. You might have some luck traceing this wire.
Good luck.
Anonymous
Level 1:
  • Posted on May 09, 2010
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
5488
Points
Yes, all it took was 30 seconds first WD40 to lubricate the sticking latch then open / close couple times problem solve. Good luck
  • Anonymous Jan 07, 2012
    very true. All i did was spray the latch and the problem is instantly gone! thanks for the hint.
Anonymous
Level 1:
New Friend:
  • Posted on May 26, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
5488
Points
My husband sprayed all of the door latches with WD40 and problem solved for this 2003 Mercury Mountaineer.
2helpful
2answers
How do I stop the door ajar sound from randomly going off while driving down the road in my 2003 Ford explorer?
The switch that turns the interior lights on when you open the door also controls the door ajar sound and light on dash board now that switch
Is either in the door hing or it's a pin switch that sticks out of the pillar post that switch is going bad you have to locate it and replace it hope this helped
1helpful
Where is the door switch on 2002 Mountaineer
Generally speaking they are inside or attached to the door latch.
If you check with the dealer you should be able to look for the part in the door once you know which version you need.
Door ajar light keeps coming on while driving and inside lights stay on when park
Bad door switch on one or more doors. There's one in each door jamb.
Door ajar light doors are closed.
very common check inthe door jam and see if the leaver which is usually black moves freely may have a wire disconnected from that
Door ajar light on and interior lights wont shut off
You more than likely have a bad door ajar switch. A technician can check this with a scan tool and tell you which switch is bad. This is a very common problem with Fords/Mercurys. GL
2helpful
Door ajar dash trouble and dome light stays on even if all doors
The door sensors will need to be replaced. A screws can be removed and then a wire can be taken of and you then can replace the switch.
1helpful
Door ajar dash light staying on
your sensor in the door lamb is bad or its the sensor for them
2003 Mountainer location of OBD2 connection
it is under the dash on the drivers side just to the right of the column.
Top MTX Car Audio & Video Experts
Jose Ramirez
Grand Canyon Tech
Grand Canyon Tech
Steve Sweetleaf
Steve Sweetleaf
Are you a MTX Car Audio and Video Expert? Answer questions, earn points and help others
