Hi my ps3 wonk connect wirelessly keeps asking for ip address
If your home is set up with wireless router and
your computers are connected online wirelessly read along....
JUST
MAKE SURE YOU DO HAVE A WIRELESS HOME NETWORK... it definitely wont
work if you don't have a wireless setup and u are trying to connect
wirelessly. people overlook this no brainer.
1) go to Settings
2)
Network
Settings
3) Internet Connection
Setting. confirm on "O.K."
4) easy *it may or may not give you a
message reading "checking network configuration"
5) wireless
from
this point on you need to know few things about your network.....
6)
scan -- once scanned it'll give you other wirelss access point for you
home network and some other near your home along with few information such as
SSID (which is what you set your network to be -- i.e. "the jones" or
"linksys" or "summer home" or "my connection" etc etc) SECURITY (this is
the password you set up your network with) SIGNAL STRENGHT (usually your
network will be the strongest among your neighbors since you are closer
to your router)
7) highlight your network and press x . (you should
know what it is) selecting on the other network will probably not do
you any good since it'll probably be all locked with password and such
and so should yours be.
8) SSID which means service set identifier
basically mean the name of your network. if your home network is set up
with security and password your home network will not show up under
SSID (this is one of the things you need to know about your home
network)
9) on WLAN SECURITY SETTING page (this is another thing you
should know about your home network or ask
the person who set it up) -- most people i deal with have a WPA-PSK /
WPA2-PSK security password yours may be different so choose the one that
you used.
10) WPA KEY - which basically means password. input the
password you used to set up your home network (this is another thing you
should know about your home network or ask the person who set it up)
**it'll give you "checking network configuration"
11) if you input
all the correct info you should get the "setting list" screen
12)
press "X" to save the setting
13)
do the connection test and if all things were entered correctly you
should have success.
all
this seems complicated just reading but if you follow it step by step
its easy. you just need to know the name of your home network, the home
network security
setting, and the password of your home network.
