Set the clock:
press function to select clock, press left or right to select the part of the clock display you want to set, press up down to set the clock.
1 Use MULTI-CONTROL to select CLOCK SET. 2 Press MULTI-CONTROL to display the setting mode. # Press BACK to return to the previous display. 3 Press MULTI-CONTROL to select the segment of the clock display you wish to set. Each time you press MULTI-CONTROL, one segment of the clock display is selected. Hour—Minute As you select segments of the clock display, the selected segment blinks.4 Turn MULTI-CONTROL to put a clock right. # You can also perform the same operations by pushing MULTI-CONTROL up or down.
Turn radio off then press and hold your knob in until you see a menu turn knob until you see the clock menu then set by moving knob up or down to change numbers and right or left to change hours, minutes or seconds. I hope this helps.
