So many factors could be affecting your reception.
Keep in mind that the digital signal is all or nothing, either you have a signal or you don't, with the regular signal you can pull in weak signals but you can't with digital.
Your converter box when turned on will probably not pick up the standard signal.
The distance from the digital signal and the direction the antenna is facing also will affect your signal.
Ok with that said you will have to clear the path between the broadcast signal and your antenna, I know this will be a chore but take your antanna out of the attic and put it outside as a test only, this dosnt mean you cant have it in the attic it will just be a signal test.
Once the antenna is moved, from the menu scan for channels and see what you get.
Let me know and I can help further.
lone99star
Btw, I’m available to help over the phone in case u need at
https://www.6ya.com/expert/jason_77a19afa8d604dee
This is the Radio Shack bought Optimus 16-176 lcd 2.3 screen.
