Pride Mobility Products Go-Go Elite Traveller 17AH Battery Pack Logo
A
Anonymous Posted on May 16, 2010
Go-Go Elite Traveller 17AH Battery Pack: whe I plug in my battery, the charge light doesn't...
Whe I plug in my battery the charge light doesn't light up... Do I need to buy another battery? help!
Anonymous
Level 1:
New Friend:
  • Contributor 16 Answers
  • Posted on May 21, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
16
Questions
0
Helped
6372
Points
20
You may need a new charger
How do I know if the battery is fully charged and working
Hi, the ideal situation is to charge them with a known good charger
Regards
Rob
www.gewizrepairs.co.uk
I got my battery pack off my Gogo Traveller Elite scooter. But the batteries are encased in plastic and I don't see a way to get them out. Help?
Turn the battery pack up side down and you will see holes around the outside of the case. With a long (12") Philips screw driver, remove 8-10 screws. carefully turn the pack back on it feet and the lid will come off. Be careful with the wires inside the battery pack and make a note of where they go.
Battery not charging fully go go elite scotter
hi, And you're sure the charger's okay ? , check the fuse located within the battery pack ...
Regards
Rob
Go go elite not charging fully
Regards
Rob
2helpful
Have got 4 year old traveller plus both lights on the charger do not come on when plugged in
The 17 amp hour batteries on this scooter rarely last more than 1.5 years. If the batteries are 4 years old, find some replacements on-line. With a long phillips screwdriver it is easy to open the battery box and replace the 2 batteries yourself. You should check the 2 fuses to make sure they are not burnt open and are making good contact. Hope this helps
How can i charge my onboard battery offboard? ineed to take the batter off and charge it indoors
Keith You have to remove the seat from the scooter and then lift the battery pack out of the frame. On the front of the battery pack there should be a charger port where you can plug in the charger into the battery pack when you are inside. Plug your charger into the battery pack first then plug it into the receptacle. When fully charged unplug from the receptacle first then unplug it from the battery pack. In other words always have the charger unplugged from the power when plugging and unplugging it from the battery pack. Velcro is holding the pack down so you might have to give it a good yank to get it off the frame. Hope this helps
2helpful
My father-in-laws gogo will be not used for several months while he's in florida. how should the battery be stored/charged while not in use?
Charge the batteries fully and remove the battery pack from the scooter. About once a month charge the battery pack. It shouldn't take long to charge since you are not using the scooter Don't overcharge when the light on the charger turns green turn it off and unplug it from the battery pack. This should keep the batteries fully charged and fresh when FIL gets back home. Hope this helps you
The new batteries that we bought for our gogo elite do not stay charged for more than 15 min of use. The batteries are only 3 months old
battery cells damaged
replace
it
its in warranty even if its not og
other third party battery makers give 6 month warranty
5helpful
I have an Elite Traveler Plus. The batteries are dead. I plug in the charger and the light indicator is green (saying charge is ok)? but the batteries are still dead. Batteries have been drained for a...
The batteries will not accept a charge, therefore the charger things they are full. When a battery sits for that long then they drain beyond the point of repair.
Top Pride Mobility Products Health & Beauty Experts
Rob Hill
Rob Hill
Grand Canyon Tech
Grand Canyon Tech
Sean Wright
Sean Wright
Are you a Pride Mobility Products Health and Beauty Expert? Answer questions, earn points and help others
