Question about Frigidaire FEF366 Electric Kitchen Range
Lifting the glass top to replace elements
I have a Kenmore glasstop and I need assistance with lifting the glasstop to replace the elements that are no longer working. How many screws should I be looking for? I think I have to lift it up but I don't want to force it and break it. Can you please help.....
I removed 2 screws under the front edge when you open the oven door
Posted on Jun 05, 2008
6ya staff
SOURCE:
How to lift up glass top for heating element replacement.
Most of these units have a few screws underneath the top at the front lip where the top of the door closes. Remove the screws and you should be able to lift the top up. Most of them also have a metal bar you pull down or up depending on the make and model on the side to hold the top up once you open it
Mar 08, 2015 | Bosch HES435U Electric Kitchen Range
How do you remove the glasstop?
Glass tops can be very tricky.
Unless you know what your doing,
it might be wise to get a tech to do it.
There are elements/brackets/clips ect ect mounted to the underside of the top also.
Why do you need to remove it,??
Mar 04, 2010 | KitchenAid KERS807SSS Electric Kitchen...
Kenmore flat top range front burner popped and now doesn't heat.
Assuming the other other elements work....
Write down the entire model number and call a local Sears parts store if there is one near you. They should give you the option of having the parts shipped or picking it up.
To change the element:
Unplug/turn power off to your range first.
Look under the front lip you should see between 2-4 screws. Remove the screws and then the glasstop will lift up. You might need some help to hold it up while you remove the front support bracket.
Once you have that bracket removed from the glasstop, you can change the bad element.
Dec 29, 2009 | Kitchen Ranges
How to replace door switch on a Kenmore 80 Series Dryer model # 110628541001
Unplug. Remove two screws under lint screen cover. Pull the top toward you one corner at a time while lifting at the same time. After lifting the top you can access the door switch.
Oct 15, 2009 | Kenmore Dryers
Ge glasstop oven
Check the element connections for good tight connections in both connectors. If ok, swap the element with one of the same size working elements and see if the swapped element works. If it does, replace the element. If it doesn't, the control switch or switch connections are the problem.
Jul 27, 2009 | Frigidaire FEF366 Electric Kitchen Range
Black spot on glasstop Kenmore stove
We Use Debruce Polish on all our cooktops. Debruce also works on stainless steel and polished granite, marble, porcelain, formica and glass. DeBruce is non-toxic odor-less and eco-friendly. You can get DeBruce on line at debrucepolish.com.
Jul 23, 2009 | Cooktops
Broken selector switch
TURN OFF CIRCUIT BREAKER. Lift out cooktop, remove all machine screws holding the glass frame. Remove plastic knobs and lift glass top straight up. Make sure rubber gromits are not ripped or torn. Unscrew the small screws on the selector switch and then lift up and tilt over the small aluminum chasis holding the switches to expose the wiring connections. Pull off the wires and pull out the defective switch. Replacre switch, connect wires, re-seat switch chasis, and secure switch with screws. Carefully drop in the glasstop lining up the switch shafts and the rubber grommets. Secure the top with machine screws and drop back in the cutout.
Apr 18, 2009 | GE 30 in. Profile JP350 Electric Cooktop
Broken glass top for my gas stove
You can buy just the glass for your glasstop stove. I too need to replace my glass...I have a whilpool electric glasstop. Its not cheap...may just buy new stove. I priced just the glass for my whilpool at the cheapest I can find for $320.00. Thats a lot. Mind you its not the elements under the glass..its just the glass! So...idk bout you, but a whole new stove might be my best option. If you want to price the glass for your model just keyword search your number and brand of stove and type replacement glass. GOODLUCK! :)
Feb 16, 2009 | Frigidaire FES367 Electric Kitchen Range
Dual element burner on glasstop range...inner element stays on
It is the burner control (behind the knob). The triac in the control has failed. $50 item, 10 minute change. Just make note which wire goes to which terminal.
I doubt that it is the control board, as the board has little to do with the stove top, but rather controls the display and the oven temperature/feedback monitoring.
Hope this helps.
Jan 14, 2009 | Frigidaire FEF366DC Electric Kitchen Range
Replacement of glass top
Unplug first! Find the screws that hold the cooktop to the range. Usually in the front just above the oven door when it is closed on the underside. This should release the cooktop. The burners and wiring may have to be removed. You can order the part at sears.com.
Apr 07, 2008 | Cooktops
Frigidaire FEF366 Electric Kitchen Range Logo
177 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Marvin
Marvin
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
