Insignia 42" LCD Flat-Panel HDTV Logo
A
Anonymous Posted on May 16, 2010
42" 1080p Flat-Panel LCD HDTV: no signal after power outage and have tried resett...
No signal after power outage and have tried resetting as directed by Directv and unplugged and took hdmi cable back to store it is good. Could it be the box from Directv
Anonymous
Level 2:
Guru:
Mentor:
An expert who has written 3 tips or uploaded 2 video tips.
  • Expert 86 Answers
  • Posted on May 19, 2010
Anonymous
Expert
Level 2:
Guru:
Mentor:
Answers
86
Questions
5
Helped
16470
Points
148
Try hooking something else up like a playstation or dvd see if it works so you know if its the box or the tv
Haier Hlh406bb
Check the outside antenna ,if you have one for direction it may have swung round,or the set could have Copt a surge,fit a surge board to mains power.
I have LC-42D65U and unable to turn on the TV after experiencing power outage. Seems like its power button works and briefly hear the sounds, but cannot see the screen. After power outage, I have reset the...
Now tv turn on have power LED and OPC LED lights indications flashes together?Yes,this problems,it is the tv Tuner signal board it is causes and the problems.That the board where the incomming broadcasting signal cable plug into it.If turn tv on.No power LED light or any kind LED lights at all.Yes.Than the tv power supply board that the cause and the problems,that the board where the tv power a/c cord plug into it.U have some basic mechanicals skills like take things aparts and putting it back together again?Yes,tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish tv Tuner signal board or tv power supply board for the replacement.
1helpful
I have a Toshiba 37rv525rz we had a power outage now the toshiba on the front is just blinking any suggestions?
Leave it unpluged for 40MIn. for the TV processor, to reset back to normal. If that does not work then replace power supply.
Sound quality has diminished after power outage
Tries unplug,replug an hour later,let the tv reset itself back to factory setting.After,turn on the tv,go to the menu,go to sound on ur menu go down to reset the sound.The functions should go back to normal,not than.Ur tv Tuner signal board have a short,in the power outage occurance.
Aquos 42 won't turn on
Try unpluging it for 30 seconds and plug it back in. This is how some electronics are reset.
After a momentary power outage Panasonic LCD TV has a flashing red light and will not turn on.
Try using a different outlet, the outlet or the tv may have been damaged in the surge. In the case of the tv contact the manufacturer and see if it's still under warranty. There may also be a way to 'reset' the tv by holding the power button down, try looking in the manual or calling customer support. In the future use a surge protector, many of today's electronics are still sensitive to power surges, older tv's were more resilliant than today's in this regard.
1helpful
Kdfe50a10 Sony lcd projection TV. No red color
Make sure you get colors by bringing the TV menu and see if looks normal, if it does
maybe the problem us the signal source
HDTV flashes on/off
Look at the Power Supply board of your tv to see any puffed capacitors. If you notice some of them failed, just replace them.
Top Insignia Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
