WHIRPOOL washer model LSR8010PQ0, WHEN LOADED WIT...
Whirpool washer model LSR8010PQ0 when loaded with towels and jeans( maybe overloaded) it wont spin it drains but she has to re- arrange clothes sometimes A couple times and it will spin.
Re: WHIRPOOL washer model LSR8010PQ0, WHEN LOADED WIT...
If large items in the machine create an imbalanced load the machine is designed to switch off...Towels are notorious for doing this because they hold so much water. Jeans don't soak up much water. Wash towels with towels alone and the problem should be reduced....Good luck....Nomess
the spider gear is broken,it would be cheaper to replace the washer than have it repaired,you either overloaded the washer or used to much detergent,you should only use two tablespoons of h.e. detergent in a front load washer or you did both,if you look at the back wall it looks like a peace sign,that's where the gear is
Hi, most of the time this can be a simple as a overload that will dramatically shake this type of washer. due to its front load design, it is recommeded to load accordingly to specs. overloading this type of washer will induce walking/excessive vibration during the spin cycle.
ld stand for long drain there is something in your pump or your drain most likely the pump you need to clean the pump or maybe even replace it if need be
