Car Audio & Video Logo
Posted on May 18, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi sir! I have a problem that you answered about a stereo in a Nissan Sentra. Only my right side works. You said to get into the stereo to test out the wires and see where the problem lies. My question is how do I get into the stereo to try this? Thanks!
Anonymous
Level 3:
  • Master 389 Answers
  • Posted on May 18, 2010
Anonymous
Master
Level 3:
Answers
389
Questions
Helped
141814
Points
1027
I can't see your radio or how it is hooked up. If it has the knob type tuning then you will need to take off the knobs and there will be nuts holding the stereo in place. There may be some screws along the edges as well that has to come out. If it is a push button then I can't help you. I would be a good idea to call a local stereo shop or if if it factory then call the dealers. hope this helped some and good luck. The Raz
2answers
2006 Nissan Sentra radio hook up
https://www.modifiedlife.com/2006-nissan-sentra-car-stereo-wiring-guide/
Hi, I have a 2016 Nissan Sentra. When the lights are switched on, only the left rear tail light doesn't come on. Brake lights work, indicator, hazards and reverse. I've checked the fuses cabin and engine...
All parking lights are on the same circuit. If there is no voltage at the bulb socket, trace the wires. Either the ground or park light wire is broken.
2002 nissan sentry xe radio wiring color code
2002 Nissan Sentra Car Stereo Radio Wiring Diagram
Car Radio Constant 12v+ Wire: Pink
Car Radio Switched 12v+ Wire: Blue
Car Radio Ground Wire: Chassis
Car Radio Illumination Wire: Red/Green
Car Stereo Dimmer Wire: Red/Yellow
Left Front Speaker Positive Wire (+): Pink
Left Front Speaker Negative Wire (-): Blue
Right Front Speaker Positive Wire (+): White
Right Front Speaker Negative Wire (-): Black
Left Rear Speaker Positive Wire (+): Light Green
Left Rear Speaker Negative Wire (-): Violet
Right Rear Speaker Positive Wire (+): Blue
Right Rear Speaker Negative Wire (-): Pink
97 Nissan Sentra will not start it just makes a noise in the back right side of the engine
good day Sir, try to check the spark plugs, ignition coil and air filter, i hope this tips will help you.
Fitting a stereo in a 1993 Nissan Sentra
if you are putting an after marker stereo the wiring is different from a stock radio some audio stores sell adapters for after market stereos that you jus clip on to stock wiring
I need a wiring color code for 2004 nissan sentra factory stereo.
I have the same car...04 nissan sentra....with the exact same problem....left side speakers just quit working. I still do not know what caused the problem, or how to fix it. I know it not the wiring, it is a defect within the stereo.
3helpful
3answers
Stereo wire diagram
1995 Nissan Sentra Car Stereo Radio Wiring Diagram
Car Radio Illumination Wire: Red/Blue
Car Stereo Antenna Trigger: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Front Speakers Size: N/A
Front Speakers Location: N/A
Rear Speakers Size: N/A
Rear Speakers Location: N/A
Where is the fuse of the stereo of a nissan sentra
Under the dash on the driver side.
Please rate this a fixya
Nissan sentra 1995 wireing help
go to crutchfield .com and let them know your car and your stereo. they are great at this.
Top Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
