Chicago Pneumatic Qrs 5 HP/3 Phase Rotary Screw Air Compressor  Logo
Posted on May 18, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
We have 15 HP motor screw compressor of cp make in its we face the problem of oil throw from its suction side ( from air filter element ) when compressor switch off pl gude me this problem as urgent
Fred Yearian
Level 3:
  • Master 5,603 Answers
  • Posted on May 26, 2010
Fred Yearian
Master
Level 3:
Answers
5603
Questions
Helped
2247320
Points
16162
Sounds like check valve doesn't close fast enough. COuld have broken spring. Also if oil level is too high that could cause it.
2answers
HI, how do I drain the oil from a Vespa 1/4 Hp air compressor?
The red cap on the left or in the middle above the sight glass on the front side of the pump
H68 or SAE30
Why doesn't my rockworth compressor fill up when it's running it's brand new
This could be an assembly error at the company. There are three valves in a compressor, one is an intake, one is an exhaust, one is an unloader. The easiest way to check is to put your hand on the intake air filter to check for suction. If there is suction then the valve is ok on the intake, if it flutters then it is bad or missing. Locate the on off switch and there should be a valve that unloads the pressure from the compressor, see if that is leaking.
What level does the coolant need to be in the sight glass?
About 31,000 results (0.83 seconds) Search Results
    [PDF]IRM-G-8780 2-25hp US - Ingersoll Rand Air Compressor
    www.ingersollrandproducts.com/...
    Ingersoll Rand Industrial TechnologiesIngersoll Rand compressors are not designed, intended or approved for breathing ...does not approve specialized equipment for breathing air applications and ... unmatched service to meet your needs. ... drain, and low-oil-level .... Oil Sight Glass ... Value Package (5, 7.5, 10 & 15hp) An economical choice in a dependable ...
    [PDF]Owner's Manual - Air Compressors Direct
    www.aircompressorsdirect.com/.../irmanual2340_2475_2545_7100_15t...
    installation, operation and maintenance of your Ingersoll-Rand air ... An air-cooled aftercooler, low oil level ... for Models 2340, 2475, 2545, 7100, 15T & 3000 ... Ifcooling of the discharge air is required, .... motor does not have this button and the unit does not have a ..... l Drain compressor oil and clean oil sight glass.
    [PDF]XF 7.5 - 15 EP 7.5 - 15 HP 7.5 - 15 XP 7.5 - 15
    diagramasde.com/.../Manual%20comp%20ingersollrand%20SSR-15.pdf
    EP 7.5 - 15. HP 7.5 - 15. XP 7.5 - 15 ... The Ingersoll-Rand Company Rotary Screw Air Compressor that has been filled prior to its ... after shall have its AIREND warranted for twenty four (24) months from the ... comes first, when using ULTRA COOLANT.Coolant ...... check coolant level in the sight glass on the separator tank.
    Ingersoll Rand Air Compressors - About Air Compressors
    www.about-air-compressors.com/Ingersoll-Rand-air-compressors.html
1helpful
2answers
What would cause compressor oil to migrate to dischage air.
If it is a screw compressor and by you saying you replaced the seperator i would say it it you need to check the scavange line. This is a pipe that goes to the bottom of the seperator filter and sucks any excess oil back into the bottom of the element (pump ) if this is blocked oil will pass down the line insted of going back into compressor. Check pipe on seperator and flex hose going from seperator vessel to bottom of element.
QRS-15 CP Rotoray screw. Is it OK to use Amsoil 20W synthetic compressor oil to top of the original ISO 68 oil it came with? Thanks Jon Owen
G'day.
I guess only if the ISO 68 oil is also a full synthetic- otherwise no.
I would not mix them.
I would want to change all the oil & ALL the filters (including the seperator) before switching between a mineral & synthetic oil.
So it would be much safer/better to top up with the same oil until the next scheduled service & then switch to the better synthetic oil.
I hope this helped(I ran a compressor repair buisness in Sydney for 10 yrs)
Kind regards Andrew Porrelli
1helpful
New air filter assembly for alton at01205-11
my compressor fell over and the air cleaner was broken. where can I purchase a new one.. Alton AE01205-11?
2helpful
2answers
My ingersoll ssr2000 rotary screw compressor trips &restart on it
Check defective HATS or Airend is defective. HATS means High Airend Temperature Switch.
40 hp rotary screw IR compressor
Check if your compressor running in low pressure. If your discharge pressure drop @65psi the result is oil carry over.
Compressor will not pressurize
A simple check to see of the compressor is pumping is to remove the intake air filter and feel for suction. If the pump is working properly you will feel suction at the intake and the compressor will unload (speed up) when you restrict the opening. If no suction remove the head and valve plate and check the piston and reed valves for damage. Replace parts as needed. Parts are not expensive for small compressors. Good luck, enjoy.
Top Chicago Pneumatic Tools & Hardware - Others Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Chicago Pneumatic Tool and Hardware - Other Expert? Answer questions, earn points and help others
