Sharp BQCXVZ100001 Projector Lamp for XV-Z10000 Logo
Posted on May 18, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
XV-Z10000I change the lamp with a new one it doen't turn on ofter replacing with the bulb, does it need rest and how can be done Thanks Zia
Lampdeng.com
Level 2:
Renaissance:
An user who is expert in 3 categories / brands.
  • Expert 789 Answers
  • Posted on Aug 26, 2016
Lampdeng.com
Expert
Level 2:
Renaissance:
Answers
789
Questions
0
Helped
197519
Points
977
Reset the lamp timer.
1,Connect the power cord.
2,While simultaneously holding down "menu","enter" and "down" on the projector, press "standby/On" on the projector and keep all four buttons pressed down until the lamp indicator starts blinking green.
"LAMP 0000H" is displayed, indicating that the lamp timer is reset.
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
2 Related Answers
Anonymous
  • Posted on Dec 23, 2008
SOURCE: sharp projector
how do i rest the new lamp on my sharp projector
Anonymous
  • 150 Answers
  • Posted on Jan 17, 2010
SOURCE: Recently I was using my xv-z90u, I started the
There is no problem here, the sharp projectors just do this until you enter the reset procedure. It comes on a sheet with your lamp. they differ from projector to projector. often involves hold down power and some arrows while plugging in the projector - that will reset the lamp timer and you will be away!
Brightness Flickering
1,the mother board is good
2,the lamp ballast is good
3,the lamp is defective, replace it with a new bulb ,
you need a new Original lamp (USD290)
Have a good day!
Jerry Lampdeng Limited
Mobile: 0086-13178867858
Wechat ID: 008613178867858
Whatapp ID: 008613178867858
Skype: [email protected]
http://www.lampdeng.com
Sharp projector Bulb replaced but still won't work?
check the ballast
Have a nice day!
Jerry
Lampdeng Limited
I replaced the lamp in my Sharp xv-z90u. When I attach the power cord I get a solid green on the power indicator light. I also get a flashing green on the lamp indicator. I tried programming the reset...
First check your bulb properly matched with your projector. After changing the lamp reset the lamp hour (counting from 0hrs). Adjust the osd transparency.
If u set the lamp properly then It may cause the lamp circuit need repair.
Have you got yellow lamp indication before change the lamp? If occur then you have been late to change it. If you used it up to 2500hrs. then this problem may arise. Check those first if everything ok then may be the circuit have some problem, go to the nearest sharp authorize service center or visit website.
I am replacing the bulb on my sharp xv-z2000 projector. i replaced it fine but the power light and the bulb light both stay red and i cant even turn the projector on. how do you reset the projector?
Two red lights indicate a problem with the lamp circuitry, i.e. the ballast. This requires a service center to change out a circuit board. Given the cost, it might be time to look for a new projector.
3helpful
Lamp life over 2000. can't turn on again after replaced
sharp xv z9000u bulb reset
Hold down Enter + down arrow + right arrow and then power on.
Sharp Projector XV-Z90 Flickering
the color wheel is dirty. It just need to be cleaned.
Top Sharp Office Equipment & Supplies Experts
k24674
ZJ Limited
ZJ Limited
Norman Weimar
Norman Weimar
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
