Televison & Video Logo
Posted on May 18, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi ,my name is jack and i hve 52 inch plasma and it giving me problem i want u help with that my problem is whenever i turn on tv it make noisce like click click and screen is blank and stand by light also not coming on give me the solution of these problem and help me out thanks
Anonymous
Level 3:
President:
  • Master 3,130 Answers
  • Posted on May 18, 2010
Anonymous
Master
Level 3:
President:
Answers
3130
Questions
5
Helped
1650434
Points
8439
We will need a model number please and maybe we can help/assist you!
Techman
Hello , my name mike I Have a samsumg 42 inch plasma model pn42A450p1d . Picture looks good other than left side has a 3 inch black section from top to bottom. Any help
Hi, My name is Amp:
If you wish to get some details; check the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
I have a 2008 46 inch Panasonic Plasma. Whenever I try to turn on the tv within an hour of turning it off, the tv doesn't turn back on and the power light blinks. To get the tv to turn on I h
I will be the barer of bad news. your Panel is failing. Plasma TVs are only made to last 5-7 years. 10-12 is more realistic from what I have seen. The TH46pz85u is a great model of TV but when that starts happening it means the panel is beginning to fail. Replacing the panel is cost prohibitive and they don't even make them anymore.
You will be wise to spend your money on a new TV. newer TV's are much more power efficient as well. your 46" TV draws a lot of electricity. Your TV draws almost 650Watts of power. A comparably sized TV today(55" or larger) Draws around 200 watts. Significantly less.
1helpful
No picture only sound ( plasma 52 inch )
Hello Fixya customer,
Thank you for your question.
There are several possibilities here including the signal source, a fault in the video processing, or panel display drivers.
This can be narrowed down further for your model. Please supply the full model number of your TV.
Thank you for using Fixya, and I look forward to your response.
Samsung Plasma 52 inch flatscreen vintage 2004 - black line
Hi my name is Roety,
I can help you with your issue ,
If the line is present on all inputs, and effects the TV menu you most likely need a new screen.
You can try changing buffers, reseating cables.
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
Thanks
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
4helpful
2answers
My 50 inch samsung plasma tv turns off and on by itself. it also clicks while this happens.
My Samsung 52" plasma TV will shut off while watching TV. It will do it repeatedly and we have to turn it back on. Is it overheating and shuts down? How can this be fixed?
52 inch Hitachi rear projection HDTV. No picture. Just vertical colored lines.
If you wish to get some details; visit the site linked here. Pull up older posts.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
1helpful
2answers
Power supply for lg plasma tv
i have a 60 inch tv i just order the power supply kit i want to install it myself do i have to open the whole back of the tv.
3helpful
2answers
52 inch RCA - green light turns on & off, BUT no picture
CP150 is a capacitor in the power supply circuit....feel top to
see if flat....change if "pooched" or swollen..................T.
RCA 52 inch TV (turn on problems and channels rolling) HELP!
Your set uses the 195 series chasis. The only thing I can think of which would make the channels scroll by themselves is a contaminated PC board and pushbuttons behind the buttons on the front of the set. This is usually the case when spray cleaner or some other fluid is sprayed or spilled on the screen, and it drips down onto that board. To prove this, remove the back cover and on the top of the main chassis, where the top of the picture tubes are, is a small PC board with the remote reciever and a couple of jacks. The smaller jack is for the speakers and the larger jack is for the front panel PC board. Unplug the larger connector which goes up to the front PC board and then turn the set on with the remote. If the set works normally, the front PC board will have to be removed and cleaned or repaired (or just leave the jack unplugged and work the TV from the remote only). If you do not have any experience working inside projection sets then allow a qualified tech to handle it for you.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
