Whirlpool 24 in. DU920PW Built-In Dishwasher Logo
Posted on May 18, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
ADP5550 dishwasher rinsing light on, start light flashing twice, but stuck will not proceed with wash. was water leakage at base of dishwasher (small amount). have cleared strainer in drain and checked for leakage. What else to do and how do i reprogramme it?
Ambari
Level 3:
  • Master 901 Answers
  • Posted on May 18, 2010
Ambari
Master
Level 3:
Answers
901
Questions
0
Helped
251340
Points
1858
Looks like micro controller problem. Contact service center for help.
Solution for Wash/rinse, Dry, and End light flashing.
There might be a blockage or the motor is stuck.
2answers
Ariston dishwasher LFB 5B010 EX on/off, rinse aid and salt lights are flashing, left washing light orange and green (end) light on without flashing.
It sounds like there may be a problem with your Ariston dishwasher. The flashing lights and the dishwasher's inability to wash could be caused by a number of issues, including a problem with the control panel, a faulty water inlet valve, or a clogged wash pump.
To troubleshoot the issue, you can try the following steps:
  1. Check the control panel for any loose or damaged wires. If you find any loose or damaged wires, try to secure them or repair them as needed.
  2. Check the water inlet valve to make sure it is not clogged or faulty. The water inlet valve controls the flow of water into the dishwasher. If it is clogged or faulty, it could cause the dishwasher to stop working.
  3. Check the wash pump for any blockages. The wash pump is responsible for circulating the water during the wash cycle. If it is clogged, it could prevent the dishwasher from washing properly.
Jan 02, 2023 • Dishwashers
Bosch dishwasher rinse aid and check water light flashing.
First you have to fix where the leak is coming from that tripped to E15 error code. You can reset by turning off power for 15 minutes.
An E15 error code indicates that the safety switch has detected water in the base of the dishwasher. Your leakage protection system has activated. What can I do to fix the E15 Error Code on my dishwasher?
E15 Bosch Dishwasher Error Code
.https://www.google.com/search?q=dishwasher+e15+error
Dishwasher light flashing
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
3helpful
2answers
'low rinse' stuck on with full rinse aid, can't start wash cycle
Actually, if you look closely at that Low Rinse button or emblem, you will see a little lock symbol above the words "Low Rinse", and I'll bet THAT light is the one that is on. Basically, you have the control lock (or child-lock) turned on. To turn it off, you have to press and hold the Sanitize button for 3 to 5 seconds until that light goes off. Now your dishwasher will work!
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
DD603 top draw cycle getting stuck on 73min??????
Normally if you started the rinse cycle with water already in the base of the dishwasher it will immediately go into circulating the water through the wash arms. Do you hear the wash arms running when the washer is stuck at 11mins? Also when the washer is stuck at 73 mins are the wash arms running all the time or do you hear the pump operate at some stage?
If you have the dishwasher manual available make sure the water pressure setting is at HI or LO depending on your rated mains water pressure.
1helpful
The normal and economy lights are blinking and cannot get to wash through a full cycle. water is in the bottom of the washer
You will have to check if the dishwasher is stuck in the drain cycle or wash cycle.
The normal and economy lights flashing means there is flooding in the unit.
Reset the unit by pressing START button for 4 secs. If the flashing does not stop then you have to call the technician. There may be a leakage which is causing the flood switch to activate.
1helpful
ADP5550 DISHWASHER RINSING LIGHT ON, START LIGHT FLASHING TWICE, BUT STUCK WILL NOT PROCEED WITH THE WASH. I HAVE PRESSED THE START BUTTON FOR 10 SECS, 30 SECS BUT THE ONLY RESPONSE IS THE PUMP ONLY RUNS...
This does sound like a problem with the "anti-flood" device that does detect water (leak / spill) at the base of the washer. This device is a protection device that consists of a polystirene float and a micro swithch. Once a water leak od spill is detected it automatically puts the washer in pump out mode. You need to determine if a leak exists that has caused the float to trigger the micro switch and clear the water / leak. This should put the washer back to normal.
I have a quite partner 2 and it is stuck on the clean cycle and the light is blinking on and off. It will not work when I push any other buttons.
whirlpool dishwashers sense the water temperature in them the clean light flashing 7 times means either the heater element is not working or the water temperature going into the unit is to cold, start the water at the sink before starting the dishwasher now to get rid of the flashing light press the hi temp wash button and then the sani rinse button press one then the other over and over until all the lights come on it will then go in to a test mode when it completes the flashing light will go out that will solve your problem
Dishwasher doesnt drain on wash cycle,ok on rinse cycle
Change the circuit board, timer/progrsmer.
Take it out and clean contacts,
Look for burnt circuit line and solder a fine bead carefully on the circuit board, difficult. Use the pot and pan program.
Vitally
Top Whirlpool Dishwashers Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
