SOURCE: tractor will not start
first,i would replace the plug.make sure your gas tank is clean,with no water in it. and adujst your carb.
SOURCE: Rototiller pull start won't pull
First thing to do, if you haven't already, change the oil, and remove all 'old' gas.
Then, after that's done, remove the plug, in order to de-pressurise the cylinder.
Then try to crank it again.
If it turns, then clearly, it's not ceased.
Remember, don't loose you're patience, just take your time.
Good luck with that:)
SOURCE: honda fr600 tiller, trouble selecting gears seems
Hello .
Honda has a service bulletin for the units with a serial # 1000001 up to 2001784 for a improved gear shift lever . I will recomend you to contact your local Honda dealer to see if they can get this improvment for your unit .
It's the servicve bulletin Tiller # 5 .
Hope this help
SOURCE: i have honda fg 110 a mini tiller it starts fine
I think even the small mantis tillers have low oil shut offs so that's always the first thing to check if you haven't already. You'll need to clean the carb off, if you remove the air filter cover and the corresponding screws underneath you'll gain access to the carb. If you don't feel comfortable dismantling it completely you can shoot the carb and choke cleaner while working the choke back and forth. Give it time to dry completely, this should not take long as it is designed to clean and dissolve rather quickly. Once you're sure there is no blockages turn the unit on and listen to it's idle, if the unit sounds as if it is reving too low than turn the idle adjustment (a black plastic screw on the carb) counter-clockwise taking care not to go too high as this could damage the engine. Adjusting the gas/air mixture shouldn't need to be done so stay away from these adjustments for the time being.
SOURCE: Sears front tine tiller....900 series, 24
The pawl ratchets seem to be sticking for some reason, try some WD40 inside the recoil. Stephen.
