GE 30" Built-In Single Electric Wall Oven - Bisque-on-Bisque Logo
Posted on May 17, 2010
Can't get the GE P7 door lock engaged in order to
Can't get the GE P7 self cleaning oven door lock engaged in order to begin the cleaning process. I'm assuming there is possibly a solenoid switch that is not working.
  • Anonymous Sep 18, 2012
    how do you get the lock to un-engage?
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Sep 01, 2012
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
4692
Points
In order to get the P7 oven to lock you must first make sure you have lifted the shields over the window before you lock the oven door. You can generall feel and hear the shielf snap into place. After doing this, close the door(make sure the interior light is off); turn oven set to clean and then push and hold the latch release while moving latch to clean before setting cleaning time on the bottom (stop) timer
  • chip carnes
    chip carnes Nov 26, 2014
    the shield on my p7 will not stay up so I can lock the door. how do i fix that?
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 1 Answer
  • Posted on Oct 23, 2011
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
Questions
Helped
943
Points
How to disconnect oven cleaner on kenmore electrict stove
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 11 Answers
  • Posted on May 17, 2010
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
11
Questions
Helped
2538
Points
13
Have to have a repairman come out and reset the code on the inbord computer not a simple fix i know i sell appliances
I can't get my GE range to self clean, I keep getting a F91 error whenever I try to clean.
Unfortunately, the F91 error indicates that the door lock is not functioning or the signal that the door is locked didn't get to the control unit. The range will not begin the self-clean cycle if there is a chance that you could open the oven door when the oven is dangerously hot.
First try cycling the power by unplugging the range (or turning off the circuit breaker). Next check if the lock has engaged. If the lock doesn't engage, check if the mechanism is bent or binding. Next check the wiring to see there is damage that will prevent the communication between the control board or the door lock. Check for corrosion at the wiring harness connections.
If the error happened after doing a self-clean, I'd suspect the door lock hadn't released. That can be related to a damaged over-temperature sensor or the lock itself. If the range has been self-cleaned before, it's possible that the lock was broken after forcing the door to open after that self-clean cycle.
You may need to replace the lock, the wiring or the control board. Please add a comment with the model of your range for a parts diagram. If your range is under warranty, contact GE.
I hope this helps.
Jun 26, 2018 • GE Ovens
Used self cleaning process on my oven yesterday and today the oven will not turn on, we keep getting message to unlock the oven door even though it is. What can we do?
The oven gets extremely hot during the self-cleaning mode... the door switch might have got stuck in locked position, or broken in locked position (to be replaced), let's hope it's just stuck...which you'll need to work the mechanical lock-unlock latching back and forth to hopefully unstick....and if that doesn't work just re-run self-cleaning process but this time let the oven cool completely before unlocking the door. Hope this helps.
May 11, 2014 • GE Ovens
2helpful
Hi lost the manual..need to start self cleaning
An electric oven is a great oven choice because of the advanced self-cleaning feature often available on certain models. A self-cleaning oven uses high temperatures to clean crusty baking spills and splatters and free its owner from having to use harsh chemicals to clean his oven. The following 4 steps lay out how a self-cleaning oven works.
Step 1 - Setting the Self Cleaning Mode
Depending on the style and brand of oven you own, you start the self-cleaning cycle by setting the oven's operating dial to "Clean," a function that can be as simple as setting a timer knob or pushing one or two buttons.
Step 2 - Cleaning Cycle
Once you have set the self-cleaning cycle, the oven coils-both lower and upper--will begin to heat. These self-cleaning ovens are protected from high oven temperatures damage by heavy insulation installed in their walls and door during the manufacturing process.
Step 3 - Automatic Door Lock
When the oven reaches a pre-determined temperature, the lock on the oven door engages, preventing anyone from opening the door until the oven temperature has cooled.
Step 4 - Removing Residual Ashes
Once the cleaning process is completed, including cooling, you can then remove the residual ash by wiping the bottom oven surface with a damp cloth or sponge.
Hope this helpout
May 17, 2011 • Ovens
Need to know how to set self cleaning ge p7 self cleaning oven
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
Sep 24, 2010 • GE Ovens
3helpful
2answers
Self cleaning oven won't start self clean mode
NO IN ORDER TO ENGAGE IN SELF CLEANING THE LOCK MUST FIRST ENGAGE. DOOR LOCK ASSEMBLY FAILURE
GE Electric Double Oven Door Will Not Unlock
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
heatman101
Asker's Testimonial " Wish I had read this first. I never would have usedthe self cleaning option. Thanks for the info!! " - amymrocks
JTP56 Self Cleaning issue
It sounds like you need to replace the door latch assembly. One of the switches on it is not working properly so the control is not getting the correct signal for the door latch position. It could be an oven control problem, but most likely it is the latch.
Post back with the complete model number from the oven if you need more help and I will answer as soon as I can.
Thanks, Mike
1helpful
3answers
1960's GE P7 self-cleaning oven
wait untill oven has colled down to room temp and press latch release button and hold in while slideing latch to unlock
Feb 18, 2008 • Ovens
Ge oven door locked
You oven is locked because it is self-cleaning. Some how the handle got moved and it initiated. You may need to let the oven finish self-cleaning. Usually, it can take about an hour to complete the process. Afterward, the oven will beep when done and your oven can be opened. Good luck.
Top GE Ovens Experts
ZJ Limited
ZJ Limited
Paul Bade
Are you a GE Oven Expert? Answer questions, earn points and help others
