Maytag Atlantis MAV6000 Top Load Washer Logo
Anonymous Posted on May 17, 2010
Agitator doesn't move and machine makes a loud "growl" but spin cycle works. This is a Maytag "Atlantis"
  • Anonymous May 18, 2010
    I think the agitator spline is not engaging the shaft. How do I remove the agitator?
Anonymous
Level 1:
Problem Solver:
  • Contributor 6 Answers
  • Posted on May 17, 2010
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
6
Questions
Helped
992
Points
16
I think washer transmission GONE!
    what's it model number?
Maytag Atlantis Washer makes loud noise only during wash cycle (not spin)
Top Loader? That sounds like a gearbox problem. It is not an easy fix. With that much use and those many years, it is probably time for a new one. A new High Efficiency Front Loader, will save you a fortune in water, electricity and detergent.
Try this forum though if you want to try and get it fixed.
https://www.automaticwasher.org/cgi-bin/TD/TD-VIEWTHREAD.cgi?71822
Washer makes grinding/loud sound and will not agitate-spins fine
Look under the washer. Is there a little pile of black rubber shavings? This sounds like the basket coupler between the motor and the drum. If the coupler is the problem it is inexpensive to fix. Some also call this part the "clutch". It kind of looks like a hockey puck with six holes in it... three for the motor, three for the clothes drum. In your case, I suspect that the holes are intact in the direction of spin, but as soon as it reverses for agitation, it breaks out through the back of the holes.
Agitator doesn't work but spin cycle works, makes a loud noise when in wash cycle but agitator is not working
This means that the transmission has failed, check the use and care guide some had a ten year warranty.
Let me know,
http://www.appliancerepairlesson.com/
1helpful
Make loud noise during spin cycle
Washer may be out of balance, Move closes around in washer and restart
Agitator stopped moving back and forth
Hi, Can you tell me if the spin cycle works? It sounds like maybe a couler has gone bad. Also check and see if the lower half of the agitator is working at all.
Please let me know and I can help you through this.
Thanks
Vic
2helpful
Agitator now moving VERY slow one way, making loud grinding noise
Hi, this is a bad transmission gear box that is stripped at the moment. i recommend purchasing a agitator kit and a new transmission Assembly and clutch as well. this will fix your issues
2helpful
Grinding niose from agitator.
If the fill and drain functions correctly, AND the spin cycle works correctly, AND the cycle itself starts and completes correctly, the problem being that the back and forth motion of the agitator starts the loud grinding noise, it will likley be broken gears in the transmission. The single most expensive part in the washing machine.
Top Maytag Washing Machines Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ZJ Limited
ZJ Limited
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
