Question about Avanti Top Load Washer W797
Hi, I have a portable Avanti washer that is
Hi, I have a portable Avanti washer that is leaking underneath the tank, but it's not leaking from the hose. The washer starts leaking after the first cycle, and I had my kitchen floated due to this problem. I need to know if this issue could be fixed, and where can I find a low cost repair technician. I really want to have it fixed because it's only 3 years old, and it’s in good overall condition. Thanks
    New Friend:
My washer is not turning or spinning could someone please help me
Posted on May 29, 2019
4 Suggested Answers
SOURCE:
SOURCE: Avanti W852 Parts??
It's going to be hard finding parts for this machine because I have one as well. You can search the internet or call the company. The last time I had problems with my machine the company told me they stop making parts for this particular brand. Don't give up looking for parts, maybe someone else sells the parts for this washer. Good Luck!
Posted on Mar 11, 2009
  • 10865 Answers
SOURCE: I can't find an adapter for my kitchen sink that
Hi. Take the hose to most any neighborhood hardware store and they will fit it for you. Often, a local mom and pop hardware will be most helpful and knowledgeable. I assure you that there is a fix for your problem. J.
Posted on Jul 31, 2010
  • 106 Answers
SOURCE: avanti w1092f front load washer leaking water from the botton
Look under and around the door and drum seals for debris. Had a coin in the seal once, took it out leak stopped.
Posted on Nov 27, 2011
Avanti w798-ss e3 error
It seems there is a fault on the main controller unit of the washer. It seems to start and then drain off in mid cycle. Now choose a different program and see if there is any change. Also check individually the inlet valve, the water level sensor and also the drain valve. Also check all the connections to the main panel.
Mar 13, 2012 | Avanti Top Load Washer W797
Avanti w1092f front load washer leaking water from the botton
Nov 27, 2011 | Avanti W1092F Front Load Washer
Windshield washer hose is leaking under the fender. Do I have to romove the fender to replace the hose?
Don't spend your time removing something that is not relevant to the problem.
The hose can be pulled easily from underneath of that washer reservoir.
First thing is to find out why the washer fluid leaks, look for the cause of the leak.
If the leak is in the reservoir, just remove the reservoir and check it.
If the problem is in the hose line, remove the hose from the "Y" connection between the two washer nozzle and pull the hose from the main outlet of the tank washer.
Hope that clears up everything!
Thanks for using Fixya!
Dec 12, 2010 | 2008 Ford Mustang
Headlight washer system leaks out all the fluid just sitting without using the pump button
first check where it's leaking from, if water dropping near front wheel it's leaking from tank first check the rubber grommet for both washer motor 1 wiper washer motor and 2 head light washer motor, both are in the water tank, if your car water dropping from front end under the front bumper it should leaking from washer nozzle in this case need to replace the head light washer nozzle. some time leaking from hose if you check from underneath you can see where it's leaking from,
Nov 20, 2010 | 2000 Mercedes-Benz S-Class
Hi! I have a avanti wash machine portable one like the one from the picture with push bottons for about 5yrs. This morning i put it on to wash a small light quilt like always , the machine is covered when...
the problem with push button washers is that the buttons can be in a partially pressed position and that causes all sorts of problems like what you describe
covered is good but a button could be partially pushed from something being placed on the cover
start from one end and press/ release all buttons to check for button problem
Nov 11, 2017 | Avanti W851 Top Load Washer
Avanti portable dryer - drum does not rotate
The belt is broken . Call Avanti to get it fixed or take it back and get it replaced .
Oct 11, 2009 | Avanti Dryers
Avanti spinning problem
One of the largest problems with this washer has been the lid switch, you must check it out with a ohm meter, if the switch quits you will lose power to the motor. Things can get caught between the tanks as well, this machine is bad for the center bearing tightening up and the spin will quit. This is a new close up pictureof a typical lid switch. You can temporarily join the wires together to test the motor and washer operations.
Apr 03, 2009 | Avanti W789SA Top Load Washer
Avanti W852 Parts??
May 28, 2008 | Avanti W852 Top Load Washer
My washing machine keeps leaking from the bottom
There are many possible cause of a leak. If it is set to portable make sure that the faucet is off after the cycle. You also need to make sure that you are not over loading the washing machine. Please refer to owners manual how much is the capacity your washing machine can take. Drain lines is also a possibility for this leak as well as the intake inlet. If it's leaking in the center most likely the bearing have broke off and you might need a new center seal. This job requires a professional to be replaced. My advice for Avanti users is to return it and buy something else that is trusted and branded for quality and performance.
Apr 26, 2007 | Avanti W851 Top Load Washer
Avanti Top Load Washer W797 Logo
1,351 people viewed this question
Top Avanti Washing Machines Experts
Ekse
Evan Benson
Evan Benson
Archie Ferrarini
Archie Ferrarini
Are you an Avanti Washing Machine Expert? Answer questions, earn points and help others
