NEC Electra Elite DTU 16D-2 Corded Phone Logo
Posted on May 17, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
We lost power and the night attendant feature is not working properly; how can this be reset to factory? We also now receive a generic voice when no phone is answered at night?
Anonymous
Level 3:
  • Master 2,335 Answers
  • Posted on May 18, 2010
Anonymous
Master
Level 3:
Answers
2335
Questions
0
Helped
882600
Points
4663
The Technician's Install Manual for this system states:
"The system manager can request a restore of either archive or the factory
defaults by exiting to the DOS prompt and executing one of the batch files
in the UTILITY directory (RESTORE1.BAT, RESTORE2.BAT, or
DEFAULTS.BAT)"
I am currently in the process of uploading said tech manual to Fixya, and will post the link to you as soon as I can.
I hope that helps.
Why my samsung corby 2 lost ALL MOBILE CONTENT..!!! plz help me
its cant retrieve that files T_T
try dis
Samsung Corby II S3850 Specifications and Features
Samsung Corby II S3850 features a 3.2" TFT capacitive touchscreen with 240 x 320 pixels resolution, TouchWiz UI, and Accelerometer. It only has 26 MB built-in memory, but you can expand the storage capacity by using external memory car up to 16 GB. The connectivity features include Wi-Fi 802.11 b/g/n; Bluetooth v3.0 with A2DP; and microUSB v2.0. For the camera, the phone is only equipped with a modest 2 MP camera with Smile shutter and video recording capability.
Other features that you can find in this phone are: Stereo FM radio with RDS; Email; Push Email; Instant Messaging; Dolfin 2.0; SNS integration; MP4/H.264/H.263 player; MP3/WMA/WAV/eAAC+ player; DNSe (Digital Natural Sound Engine); Find Music recognition service; Organizer; Document viewer; Voice memo; Predictive text input; and more.
Dimensions: 109.9 x 60.6 x 11.7 mm (4.33 x 2.39 x 0.46 in)
Weight: 102 g (3.60 oz)
How to Reset Samsung Corby II S3850
You can perform a factory data reset to restore your Samsung Corby II S3850 to the factory default settings and erase all data on your phone's memory (messages, pictures, contacts, etc). To reset your Samsung Corby II S3850 simply type the following numbers on your phone: *2767*3855#
Or
Press the following button: Volume Up button + Menu button + Power button at the same time. The select Wipe Data Factory Reset using Volume button. (see below figure)
Keywords:
s3850 hard reset,samsung s3850 hard reset,hard reset s3850,
How do I fix voice mail and auto attendant features lost on Nortel Norstar mics 4.1
You can restore a recent configuration backup from diskette but if you don't have a backup you will need to rebuild the configuration from scratch. You may also have a failed hard drive or a failed supercapacitor that did not retain memory when the power was cycled. These components will need to be replaced before you continue with reprogramming.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/dave_fb2c45146b845cea
I have a Panasonic 6.0 DECT Talking ID Caller phone system. I lost my message that callers hear when the answering machine answers the phone. Somehow my granddaughter's voice has been recored and that...
Making Use of the Voice Mail Service
From your own extension
VPS* Extension No.
Mailbox
· If you have no password, you can skip the last step.
* VPS: Voice Processing System
From someone else's extension
VPS Extension No.
Mailbox No.
Mailbox Password*1 +
Listening to a Message
Password*1
KX-TVA series
Listen to Message
Deliver Message
Mailbox Management
Automated Attendant
Message Notification
Other Features
End Call
KX-TVS series
Listen to Message
Deliver Message
Check Mailbox Distribution
Automated Attendant
Mailbox Management
Other Features
End Call
VPS Extension No.
Leaving a Message
Mailbox No.
Enter the desired mailbox no.
To send the message immediately
Leave a message
(KX-TVA series)
(KX-TVS series)
Follow the guidance
To set the delivery time
May 24, 2011 • Cell Phones
How do you erase and change after hours greeting?dhalman
Call voicemail by pressing the Intercom button then dialing 777, when it answers login by dialing 99# followed by the password(default is 1234#) then press 9 for system features menu. Press 3 to choose Automated Attendant, the system prompts for the Auto Attendant number(1-4), start with Auto Attendant 1,if you do not know which one is being used by pressing 1. Press 2 to choose Night Menu, press 6 to change the Night Menu prompt. Lift the handset, press 1 to record your new Night Menu prompt using the handset, press 1 at the end of your recording. To listen to the new recording press 23, to immediately re-record press 21, to save the recording press *#. Press # to save all programming changes and activate new recording. Press *7 to return to system features menu or hang up to end programming session.
Changing the Auto Attendant prompt should be done when you are able to do a test call on each line to verify that you have changed the correct prompt(in your case after hours or by putting the system in After Hours mode manually to ensure the After Hours prompt is active) for each line being answered by the Auto Attendant. By default all lines are assigned to Auto Attendant 1, if your system has been modified to use a different Auto Attendant for some or all lines, you will need to repeat the above procedure for the Auto Attendant being used. If at any time you get lost or confused while in the voicemail programming, hang up and start over. Once you get comfortable with navigating the voicemail programming, it gets easier. If you have trouble send a comment, I will try to help.
1helpful
Old Meridian system resetting automated attendant
The passwords your using are for the voice mail and not for programming the system. The system login and password are feature**266344 with the password of 266344.
Hello I would like to know how to diconnect the Auto attendant feature during the day and reset it at night, how can I do this?
It sounds like your auto attendant is DIT for both day and night. You can setup a schedule in programming and use the night mode function, but it depends on the type of system. It is a little more detailed o program, you should have a tech do it or call for remote support and someone can walk you through it.
ldtsnj,com
AT&T Merlin Legend Console
It should be a night button on that MLX 20L. But there are TONS of ways to make that system do what you are describing. It woould take a vendor to dial in and pull some prints top say exactly.
2answers
Voice mail on/off
Try hitting feature 80 feature. It should work from any phone on your system.
Top NEC Lands Phones Experts
ADMIN Andrew
ADMIN Andrew
Don A
Don A
RAJA NADEEM AKHTER
RAJA NADEEM AKHTER
Are you a NEC Lands Phone Expert? Answer questions, earn points and help others
