MicroBoards GX-1 50 Disc DVD/CD Publisher - Shipping Burner Logo
Posted on May 17, 2010
MICROBOARDS PRINTER LANGUAGE MONITOR........UNABLE TO READ DEVICEID......................this is the error i get when trying to print to my Microboards GX auto printer
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Nov 29, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1466
Points
The Microboards G3 is the worst duplicator I have ever owned. It has worked a total of 4 times, no response from the company, software is terrible and faulty and I'm pretty much over it. Good luck.
2 Related Answers
Anonymous
  • 1833 Answers
  • Posted on Jul 06, 2011
SOURCE: microboards gx-1 printer wouldn't accept flow
Hi, For your problem you need to clear the memory. You can reinstall the software. Then turn it off and unplug it. After some time (2-3 minutes) plug it again and turn it on. You may need a firmware update for this device. Cancel all pending print job and reboot it, I will help you.
Anonymous
  • 6 Answers
  • Posted on Aug 17, 2010
SOURCE: microboards pf pro refill cartridge
you can now get continuous inking systems for the microboards pf-pro machines
see here:
http://www.jpldisplays.com.au/catalog/product_info.php?products_id=4150
2answers
Error 0x000005b3 epson 4200c
Following is the solution for your problem.
Uninstall the printer software after unplugging the printer and remove it from the network , if it in on network.
Download and install the latest drivers from thee Epson webiste for your operating system.
makse sure you are using the admin account to install the software, once installed it will be working fine.
DISC STOP FEEDING AUTO TO PF-2 PRINTER MICROBOARDS PRINT FACTORY..
Most likely the gravity fed disc cingulator needs to be replaced. My company can replace that Microboards Printer part for you. Call 952.944.0083 or visit.
Microboards DX1 input problems
Microboards' New DX-1 Disc Publisher to Ship Microboards’ New Print & Burn DVD/CD Duplicator Ships
Industrial quality of DX-2 and Print Factory in a Compact Package with the DX-1
Chanhassen, MN, August 17, 2004 —Microboards is shipping a new disc creation system (MSRP $2,995) with a high-speed DVD/CD recorder and industrial printing technology from HP to give users professional publishing in a petit package. Combined with custom label design and recording software, the system makes in-house disc creation easy and inexpensive.
You've got an expensive unit (see below for Press Release), with a built-in CD/DVD reader/writer.
Given that your unit could be six years old, it's possible that the reader/writer has "died".
It seems to be a "stand-alone" unit -- not something that requires either Mac OSx or Windows XP/Vista/7 to operate.
I'm guessing that _ANY_ IDE (not 'SATA') HP-brand reader/writer, provided that it has a "LightScribe" capability, could be purchased, and could be inserted to replace the "dead" reader/writer. For about $100, it's worthwhile to try this "substitution" to revive your unit.
____________________________
Chanhassen, MN, August 17, 2004 — Microboards is shipping a new disc creation system (MSRP $2,995) with a high-speed DVD/CD recorder and industrial printing technology from HP to give users professional publishing in a petit package. Combined with custom label design and recording software, the system makes in-house disc creation easy and inexpensive.
3helpful
Microboards pf pro refill cartridge
see here:
1helpful
Printer aio 926 communication error
hi aweintra,
you can do the following steps:
1.Check if the firewall is blocking any printer services
2.Check what port the printer is using (reenable the bi-directional support) and if it's on online mode
3.Disable all the firewalls
4.Uninstall the printer driver and software, then unplug the usb cable of the printer.
5.Delete any items under the ff keys:
HKLM\System\CurrentControlSet\Control\Print\Environments\Windows NT x86\Drivers\Version-2
HKLM\System\CurrentControlSet\Control\Print\Environments\Windows NT x86\Drivers\Version-3
HKLM\System\CurrentControlSet001\Control\Print\Environments\Windows NT x86\Drivers\Version-2
HKLM\System\CurrentControlSet001\Control\Print\Environments\Windows NT x86\Drivers\Version-3
Optional***
6.Delete any non default items under the ff keys:
Note: ONLY THE NON DEFAULT ITEMS SHOULD BE DELETED
HKLM\System\CurrentControlSet\Control\Print\Monitors
HKLM\System\CurrentControlSet001\Control\Print\Monitors
Default items are as follows:
AppleTalk Printing Devices
BJ Language Monitor
Local Port
PJL Language Monitor
Standard TCP/IP Port
USB Monitor
Windows NT FAx Monitor
7.Delete any items under the ff keys:
HKLM\System\CurrentControlSet\Control\Print\Printers
HKLM\System\CurrentControlSet001\Control\Print\Printers
8.Completely remove drivers by doing the ff: (Option for comm failure because of the upgrade from xp to vista)
Ensure there are no documents in queue.
Disconnect printer’s USB cable.
Click the Start pearl, then click All programs, Printers, Dell xxx (where “xxx” is the printer model number) and then Uninstall. Complete the uninstall utility.
From the start search box type spool and press .
The spool folder located at c:\windows\system32\spool opens.
Rename c:\windows\system32\spool\drivers\w32X86 to c:\windows\system32\spool\drivers\backup.
Rename c:\windows\system32\spool\prtprocs\W32X86 to c:\windows\system32\spool\prtprocs\backup.
9.Restart the computer.
10.Check th services status
Start-Run- Type Services.msc and Click on Open
You will see long list of services
You need to make sure following 4 Services are set to Automatically start
Remote Procedure Call RPC
Remote Procedure Call RPC Locater
LexBce Server
Print Spooler
11.Reinstall the latest printer driver
just send me an update if the issue won't be fixed. have a great day.
Black or Blue not printing - just red and yellow
Are you using geninue Microboards new cartidges or refills? If you are using the new Microboards ink carts, then you have a bad cartridge, or possibly a bad batch. Simply call Microboards tech support at 952.556.1639.
http://www.techwaredist.com
Microboards PFII just keeps rolling discs and will not print
Di arleady did the first thing that we advise of customers to do - reload the PF-2 print drivers. Since that did not work you a most likely looking at needing the print engine replaced. This typically costs $600+ depending on how full of ink the inside of your printer is. Hoefully your printer is still under warranty with Microboards. If not, you can call Microboards at 952.556.1639 or check ou this repair company
http://www.techwaredist.com/repairshop.asp
Pf3 microboard printer not working
Use Windows XP Professional or 2000 professional for best results.
- techwaredist
Error light and no printing
What does the status monitor message say? The red light is the most general error. It's bit like taking a 747 back to Boeing and saying there is something wrong with it.
If you do not have the status monitor installed, download it from Konica Minolta and run it. Once the status monitor is running it will read the error from the printer.
Top MicroBoards Computers & Internet Experts
 Grubhead
Grubhead
ADMIN Andrew
ADMIN Andrew
Antonios
Antonios
Are you a MicroBoards Computer and Internet Expert? Answer questions, earn points and help others
