When I try to connect to server with hyperterminal I didn't receive any things on the screenHello,
Thanks for your replay, But my problem is :
Re: Is there any procedure to boot DL380 G4 in single...
Connect the keyboard, mouse, monitor, network cable and power cord. press the power button on the front panel of the server. If the OS is installed the server will boot.
you mean remote desktop or hyperterminal? Hyperterminal is used to connect to switches and terminal devices which your DL380 is not. Let me know what you want to do with the hyperterminal.
You can't post conmments that contain an email address.
If you mean your windows administrator password is not working and you want to change it and want to boot in safe mode then use the option of F8 at boot time this should take you to safe mode of windows. You can also use Hiren Boot CD to change administrator password if you own that server. Hope this answers your question.
We had the same problem with a G5 version of the dl380, no video at boot or OS boot. This model fortunately had another video out on the front panel that worked. However, I believe that the G4 does not have that option coupled with using the Rage XL's from ATI for video. Have you tried installing another video card into the expansion slots for video? If you are able to, you may find that when you run your smartstart and load/reload the OS your video will work with the onboard.
Make sure the BIOS is fully updated from the HP website. Most DL3-series servers supported booting from an external USB cd, try F10 or F12 at boot in order to bring up a boot menu.
I'm trying to boot in single mode, We lost a root password
