Whirlpool Duet GHW9150P Front Load Washer Logo
Posted on May 17, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Controls locked The "controls locked" light is on. I have reset the power, but that was no help
Anonymous
Level 3:
  • Master 5,911 Answers
  • Posted on May 17, 2010
Anonymous
Master
Level 3:
Answers
5911
Questions
6
Helped
2735564
Points
22413
The Control Lock is a safety feature that enables the consumer to lock the control panel to prevent small children from manipulating the controls and accidentally starting the appliance. This can usually be reset and does not require a technician.
With the lock on, the control panel is disabled and you cannot use any of the controls, except the button to unlock it. It can inadvertently be set following a power outage, leaning against the control panel, or pressing and holding the wrong button. This is usually not an indication of a malfunction.
If this is a Whirlpool manufactured appliance (such as Kenmore Elite or Whirlpool Duet), the following link explains how to lock/unlock this feature:
http://www.fixya.com/support/r3608801-control_panel_lock
These instructions are also printed on the front panel of the appliance and in the owner's manual.
If this does not correct your problem, then you may have a more serious problem than a simple operator control button issue (such as an operator console problem or main control board issue). Please post back and let me know if you need further assistance.
Maytag fridge bepping lights out MFI2568AES...fridge and freezer working..what could it be... Beeping all night long..
Fridge keeps beeping or buzzing: The following is for Frigidaire models but others can be addressed similarly.
Several Frigidaire refrigerator models have an electronic control panel on the freezer door the owner can use to adjust the internal temperature, dispense ice and water and receive notification about issues such as the need to replace a water filter. The refrigerators also emit a beep for various actions and as an occasional alarm. Determining what causes the beeps necessitates some troubleshooting.
Temperature Controls ·A Frigidaire refrigerator's display panel blinks when the control panel is touched to set temperature controls. After pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, press the arrow buttons within five seconds to increase or decrease the desired temperature. If you do not press the arrow buttons within five seconds after pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, the refrigerator beeps to indicate the current setting will stay in place.
Door Open ·When you leave the refrigerator or freezer door open, the refrigerator beeps. Also, the "Door Ajar" indicator illuminates on the appliance's display panel. Shutting the door and pressing "Alarm Reset" stops the beeping and turns off the "Door Ajar" indicator light.
·The Frigidaire refrigerator has a control lock feature that prevents use of its control panel or dispensers when the unit is locked. When the control lock is active, a beep sounds when a keypad or dispenser is pressed. Release the control lock by pressing the "Control Lock" icon for three seconds. A beep will sound, and the icon's light will go out.
Power Reset ·A power reset is occasionally necessary if the Frigidaire refrigerator's control panel does not work normally or a reset function on the keypad does not work. A power reset involves disconnecting power to the refrigerator by unplugging its power cord from the electrical outlet, waiting 30 seconds and plugging the power cord back into the electrical outlet. When the control panel resets, a beep sounds. If the refrigerator beeps even after a power reset and the beeps' source is not known, contact Frigidaire.
Read more :
Cause of Beeping Noise in Frigidaire Refrigerator eHow Refrigeration System Basics Chapter 1
Hey my Samsung cooltech plus is making beeping noises fridge temperature is jumping from one temperature to another while the beeping noise is going on. Can anyone please help me thank you
Read more :
http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.
http://www.appliancerepair.net/refrigerator-repair-1.html
Refrigeration System Basics Chapter 1 Cause of Beeping Noise in Frigidaire Refrigerator eHow
Fridge keeps bleeping
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.
Model E402b. Why is the alarm going off?
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.html
Cause of Beeping Noise in Frigidaire Refrigerator eHow Cause of Beeping Noise in Frigidaire Refrigerator eHow
Fridge & freezer lights and the water display light beep and flash 10-12 times every few hours. Simultaneously a fan motor starts and stops. Any one know what needs to be done to remedy this?
Refridgerator beeps
Fridge keeps beeping: The following is for Frigidaire models but others can be addressed similarly.
Got fridge freezer but no instructions. Alarm keeps going off. Front panel contriols
How do you get the model 370lb to stopping beeping
Keeps beeping without stopping
MY FRIGIDAIRE FRIDGE IS BEEPING AND NOT STAYING COOL
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
