I have sonyericsson k800i,.my problem is a cant go to menu,then i press the menu i show configuration error.please contact your network or service centre..please help me. i like k800i is sO nice..
You can unlock your SONY ERICSSON K800i from www.Wickedunlock.com . This is the safe and reliable online site to purchase accurate unlock codes at affordable cost. The unlocking process is very simple here. You will get easy step by step instructions on unlocking process from here. Here is the unlocking steps for Sony ericsson K800i, 1 - Switch ON your Sony Ericsson K800i without any SIM Card,
2 - Press the left arrow key/button once,
3 - Press the button * twice,
4 - Press the left arrow key/button once,
5 - The message "Personalize with MNC2" will appear, (or you will have
displayed an unlock menu, select the lock you want to unlock)
6 - Enter the Unlock Code.
How did you Set up Bluetooth on the Sony Ericsson K800i ?was it set up properly?Sony Ericsson K800i has Bluetooth technology, which can connect to other Bluetooth devices like handsfree headsets, or let you easily swap files like pictures, ringtones, videos or contacts with other people for free. It works by looking for other Bluetooth devices nearby and then connects to them to wirelessly transfer files. this is the steps to seeting up bluetooth on k800i sony ericsson
From the Menu screen, select Settings
Scroll across to the Connectivity tab and select Bluetooth
Scroll down to Phone Name and press select
Enter the new name for your K800i
Once you’ve done this, you can turn Bluetooth on to make you visible to other devices by following these steps
Select Turn On
To connect your Sony Ericsson K800i to a handsfree device, enter the Bluetooth menu screen and select Handsfree, Your phone will then look for a handsfree device to connect to. When it’s found it, select the device and enter the passcode if required
Try using a different Sim, and see if it works. if the problem persists.
You can do a reset to factory settings, which will delete all the installed softwares and also if there are any malicious files which could be the cause of problem. But take a back up of data and contacts as even that would be deleted.
You need to get the Settings for Internet/Wap and MMS from your Network Service Provider. These settings are usually sent as a text msg. When you receive the msg. choose save or install on your phone. Or get the settings directly from their website. The MMS service doesn’t always work between networks.
i got sony ericsson w580i. i can't
operate my mobile as on screen shows "configuration error. pls. contact
your network operator or service centre" i did contact my network
operator but confirmed that my sim is in usual working state. i can
only listen to call but i cant go to main menu,neither i can listen to
song. even i cant able to make call. pleasehelp me
