4-The Vaio Recovery Wizard will launch. Follow the
instructions given as you advance through the wizard. When prompted,
confirm that you want to reset your Vaio to its original factory
settings.
5-Allow the computer about an hour to properly restore itself to factory settings.
To enable the Function keys in the Computer, it is required to install VAIO Event Services. In older Computers, the application was called Hotkey Utility and in the newer Models, VAIO Event Services is used to enable the Function keys. You can download the VAIO Event Services (Notebook Utility) from the link below.
You can slove it from the safemode .There are few methods to slove your problem.
Switch on the system.then press F8 go to safemode and after enter into the windows in safemode goto the unistall the program and uninstall the nero and goto start menu, then run type "mcsonfig" goto startup tab and unselect the all the programs in the start up and reboot the system .try it and inform to the fixya.com
