Hi there my kids lost the manual of smeg dishwasher can any one help me to to show how to drain disher after finishig of use of it i mean what to press thanks
My dishwasher is draining on the floor not through the drain tube. I disconnected the drain tube off from the drain under the sink. Ran the dishwasher to see if there was a clog but the water drained onto the floor.
Thanks for writing to Fixya.com.
To fix a dishwasher that will not drain, remove any clogs that are blocking the drain line by pouring a paste of baking soda, vinegar and water down the drain, and then pouring boiling water to clear the clog. Repeat the process several times to remove a severely clogged dishwasher drain. Thanks for contacting Fixya and please accept the solution if it has helped you.
SOURCE: Dishwasher draining - Bosch SGV4313GB/17
This is generally because of a stuck diverter solenoid. The water goes to the pump and then is either sent to the wash arms or the drain. Also, check the drain.
SOURCE: dishwasher not draining
the first things to look for, are the simplist faults.
1:) Check that the Outlet Hose-Pipe Isn,t Blocked-Kinked Or Bent.
2:) Check that the Pump, is not clogged/Blocked or not-functioning.
Hope this helps you start, your fault-finding successfully.
Mike @ Compurepair.
SOURCE: Whirlpool dishwasher will not start
I have a quiet partner I and it is doing the same thing!
I have only had it for 3 months. It did it once before, then after about a week, I tried it again and it worked fine?
I can't find my warranty anywhere. I bought it at Lowes.
Does anyone have any kind of solution? Looks like it is a common problem.
SOURCE: GE Nautilus GSD4200 Dishwasher will not wash/drain
The average life of a dishwasher is 7-10 years. The symptoms strongly indicate a motor pump problem and my personal opinion is if that is the case youd be better to put the money toward a new dishwasher.
