Sony 36XBR450, no picture, no sound, power button you can hear initial power up then nothing except blinking 'stand-by' light. Something loose that I can fix or need a $69.00 visit with $1.00 per mile surcharge?
my sony KV-36XBR450 also stopped working tonite - no power, no sound, no picture - the blinking stand-by light says 7 when powered down and 4 when powered up... I need help! do you suggest I open it up, call for a pro ($$$) or replace it with a new set - purchased in Feb 2002 from Circuit City - thxmy sony KV-36XBR450 also stopped working tonite - no power, no sound, no picture - the blinking stand-by light says 7 when powered down and 4 when powered up... I need help! do you suggest I open it up, call for a pro ($$$) or replace it with a new set - purchased in Feb 2002 from Circuit City - thx
You can't post conmments that contain an email address.
I'm also having the same problem with no sound or picture, only a blank screen with the standby light flickering. Need help desperately as I live overseas and the techs are horrible. I have a tester and can troubleshoot certain area if directed. Ben
You will not be able to service this at home. Most of the time there are failures in the scan amplifiers and or the power supply that cause the fault you are describing.
Hi, TV needs lamp replacement as existing lamp got weak or has been reached to end of its working life, please note that lamp is not dead or broken so that is why lamp lit is not lit at tv front. Hope these info will help you. Thanks.
Hi i have a pilips 42" plasma tv (42PF5320/79) i can hear clicking the green light is on and the tv will go into stand by if i press the power button and the red light also comes on .I have turned it on and off and it works now nothing just the light on the front as if its working looking at the back through the slots two green lights come on then the tv clicks and they turn off,thanks
Hello Bob61E,
life safty should be 1st priorty before opening of TV set ;)
if you are skilled or qualifeid, then go-ahead and
if its Sony TV, you will see stand-by light blinking while tv try to power up. let me know how many time this light blinks.
Most probably,the secondary power output of your TV's switching power supply is not functioning.You have to trouble shoot the secondary power which also leads to HT supply in the Horizontal circuitry.
I own a Sony T.V. model #KV36HS510, Serial # 9024184,Event# E36002407 and it"s aTrinitron brand name. Like the problems before no picture or sound, stand by light on front of unit flashes. When trying to turn it back on you can hear the power click, like it wants to turn on, but does not.
