Crosman (4032) Logo
Posted on Apr 01, 2008
Reassembling a crosman 760 pumpmaster airgun
Could use a good diagram or repair instructions for putting trigger section and housing back together.
  • 28 more comments
  • Anonymous May 09, 2008
    MY OLD FAITHFULL POWERMASTER 760 WOULDN'T HOLD AIR CHARGE I REMOVED ALL THE SCREWS ON THE RECIEVER HOUSING AND PROCEEDED TO INVESTIGATE. THATS WHEN THE PROBLEM DEVELOPED. I NEED TO FIND A SCEMATIC DRAWING TO REASSEMBLE IT. ALSO NEED A PARTS KIT TO RESTORE THE GUN IF THEY ARE AVAILIBLE. I KNOW I COULD BUY A NEW ONE FOR UNDER $40, BUT THIS ONES ONLY 37 YEARS OLD AND HAS BEEN WORKING GREAT UNTIL THIS VERY ABRUPT FAILIER.
  • Anonymous May 13, 2008
    reassembling a crosman 760 trigger section
  • bbc9 Jun 30, 2008
    Mine would not fire after being pumped up so I took apart but in doing so parts just fell on the table I cleaned everything and now need a diagram to put it all back together. I would appreciate any help, thank you
  • ginnypig284 Jul 23, 2008
    i took my 760 apart to clean it and i dont know how to put it back together but i need a clear enlarged diagram to beable to figure it out can you help???
  • jim hess Jul 24, 2008
    son inlaw took triger out i dont now how to get it back in the fifle properly
  • Anonymous Jul 26, 2008
    how to put a 760 crosman trigger back togeter
  • pigtail Aug 15, 2008
    I can't put my crossman 760 pumpmaster trigger assemble back together do you have any diagrams...???????
  • caryl188 Aug 15, 2008
    need diagram of Crosman Powermaster 760 BB Repeater /.177 pellet
    Having trouble finding where spring goes back - a diagram would be very helpful
    Thanks
  • bullit120 Aug 31, 2008
    trigger and spring need to be replaced.itook gun apart to clean and unclog
  • Anonymous Sep 03, 2008
    the spring is off and it wont let me fore the trigger??
  • Anonymous Sep 04, 2008
    need to reassemble pumpmaster 760
  • burkart_burk Sep 04, 2008
  • Anonymous Oct 13, 2008
    i cant put it back together
  • Danney Mills Nov 21, 2008
    I have the same problem
    I have a prpblem reassembling my 760 air rifle
  • Anonymous Dec 18, 2008
    i have a crossman pumpmaster 760 and cant get it back together
  • Anonymous Dec 20, 2008
    need to rebuild it
  • baddog125 Jan 22, 2009
    trigger fell out to fast for me to see how to put it back!!! HELP!!
  • vader3321 Jan 24, 2009
    my crosman .177 cal. keeps losing air and i'd like to know how to fix it and restore it to its original power
  • Anonymous Jan 31, 2009
    reassembling crosman 760 pumpmaster airgun
  • nchuntington Feb 02, 2009
    I am having trouble reassembling the trigger spring on a crosman 760 also.
  • Anonymous Mar 01, 2009
    i tried to take appart my gun but dont know how to put together.
  • Anonymous Mar 21, 2009
    can't seem to put the trigger assembly back. can someone send me a diagram? thanks
  • abcba Mar 28, 2009
    can't reassemble
  • Anonymous Apr 27, 2009
  • Anonymous May 01, 2009
    Tyhe barrell is not broken, but it is twisted ( the site is misplaced)
  • Anonymous May 17, 2009
    I took apart my 760 pumpmaster .177 caliber pellet/BB pepeater and now i have some pieces i am not sure where they go if some one could help me that would be great
  • sexymomma26 May 17, 2009
    I have a 760 pumpmaster .177 pellet/BB repeater and I took it apart but now i dont know how to put it back together if any one could help me on how to put it back together that would be very apprecated
  • Hippy86 May 11, 2010
    I need to resemble my 760 pumpmaster, my trigger and spring, Can anybody HELP ME?
  • Anonymous Mar 14, 2014
    need to locate parts number for missing front sight on crosman 760-D pumpmaster
Borderlander
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Dec 03, 2014
Borderlander
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
48982
Points
39
Anonymous
Level 1:
  • Posted on Nov 23, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
48982
Points
22
The trick to assembling the trigger mechanism is to assemble the trigger parts on the left half of the receiver. This will leave the v shapped spring hanging out the bottom of the trigger guard. I assembled the barrel to the right side of the receiver and then but the two halves together. loosely attached the halves with the two long screws. I then used a jewlers screw driver to work and hold the end of the V spring behind of the safety button hole. At this point I inserted the safty button into the hole as I gradually removed the screw driver. Then clamped down the attachment screws.
I spent some 2 hours figuring this trigger assembly out and another half hour putting it together. The biggest mystery was the use of the L shapped part. It ends up being assembled to the trigger pin. the cleat catching the back of the trigger and the long side of the L laying against the left side of the receiver (pointing up). The small tention spring ingages the back of this L shapped part (just above where the cleat ingages the trigger) and the other end of the spring ( the straight end) rests against the bottom of the receiver.
Anonymous
Level 1:
  • Posted on Apr 16, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
48982
Points
15
  • Anonymous Nov 05, 2011
    As that iconic kid from from Mississippi once said, "thank you very much..." I hate sending things away I can repair my self.
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Mar 08, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
61277
Points
29
There's an exploded view available on the crosman website.
That's how I fixed mine.
http://www.crosman.com/pdf/manuals/C760-EVP%20&%20PL2.pdf
Hope that helps :)
wankelrotor
Level 1:
Problem Solver:
  • Contributor 5 Answers
  • Posted on Mar 30, 2009
wankelrotor
Contributor
Level 1:
Problem Solver:
Answers
5
Questions
0
Helped
53001
Points
13
Http://www.fotolode.com/images/Rapidfirex/crosmanpumpmaster760assembly.jpg
Matt G
Level 1:
Problem Solver:
  • Contributor 6 Answers
  • Posted on Jun 01, 2010
 Matt G
Contributor
Level 1:
Problem Solver:
Answers
6
Questions
Helped
49693
Points
14
Thanks for the answers here. With the descriptions and photos, I was able to get my old 760C back together. Turns out all it needed was some oil in the pump chamber (just like the little sticker says..."3 drops". Ha!) But taking it apart gave me a good chance to clean and oil everything. Plenty of crud in there from the last 20+ years. It's back together and shooting nicely.
I followed j-momkelly's instructions on the trigger assembly with one change. When reassembling the trigger, I put the safety button in, and used the spring to hold it in place. As long as the big side of the button (left side of the receiver) was flush with the plastic, it held in place nice and tight as well as straight. Then the left and right sides of the receiver went together nicely without too much coaxing. The exploded view on the crosman sites above helped immensely as well.
Anonymous
Level 1:
  • Posted on Apr 18, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
48982
Points
Did you try to get the diagram from www.crossman.com?
Anonymous
Level 1:
  • Posted on Sep 19, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
48982
Points
I could also use a good diagram or repair instructions for putting trigger section and housing back together. Gun is about 30 years old.
Anonymous
Level 1:
  • Posted on Apr 01, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
48982
Points
Hi my rifle isnt a crossman so dont know if you can help its a umarex 850 airmagnum
A
Anonymous
A
Anonymous
Its real easy... I took mine apart and learned how to assemble it within 10 minutes. Look at the pic on google!
A
Anonymous
Try this site
http://www.crosman.com/2004/pdf/manualarchive/C760CLIP-EVP%20&%20PL%201.pdf
Anonymous
Level 1:
  • Posted on Sep 12, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
48982
Points
I would like to know if anyone out there knows how to assemble a crosman 1088 pellet gun? email me at [email protected]
Daisy Pumpmaster 760. How do I reassemble?
PDF]OWNER'S MANUAL - Crosman
www.crosman.com/pdf/manuals/C760-OM1.pdf
Crosman Super. ' Pells® or Crosman Super. BBs®. Reservoir ... 'WARNING: Pelletsshould never be-put F'6_ into the BB Loadlng Port . They will iam ... BB How To Load Your 760 Rifle with ... see REPAIR SERVICE section of this manual. ' '.
Crosman 760 Pumpmaster assembly - YouTube
? 3:56
https://www.youtube.com/watch?v=OeOLKDYnGoE
Nov 16, 2008 - Uploaded by stonie stonemaker
Crossman 760 Pumpmaster air rifle in pieces? ... I can't close the bolt there's a little metal part that's not ..
Dec 25, 2015 • Optics
Crossman repair
I have a crossman pulse r78 and it will not shoot ,when you pull trigger it Gus windes oner spring do not egage
1helpful
Lost key for trigger lock for Crosman 760 Pumpmaster. Where can I find a replacement or get the lock off without breaking it.
As the trigger guard is only plastic and molded with the side plate, I would take it to a Locksmith as they have specialty tools for this. This may cost a few dollars, it's better than damaging your riffle.
Out of order
from a gun shop
6helpful
Crosman pumpmaster 760
Follow this link for an actual photo it's simple to follow
3helpful
3answers
Crossman 760
picture of pumpmaster 760 trigger assembly
4helpful
5answers
Fix crosman airgun
need bolt for crosman silhouette sport pistol looks like a crosman 2300T are they the same? if so where can buy bolt
13helpful
3answers
I need to reassemble a crossman airgun model 760-D
i need a website adress or link to a understandable diagram of how it goes together
Repairing
http://www.crosman.com/airguns/service/manuals/crosman-rifles
There are two manuals for the 766 on this page.
My problem is figuring out how to take it apart.
Top Crosman Optics Experts
ZJ Limited
ZJ Limited
NOEL
NOEL
Are you a Crosman Optic Expert? Answer questions, earn points and help others
