Hand home positioning normally has nothing to do with time setting.
Just set your local time and date and then you can do the hand home positioning procedure.This will not affect the time setting.If hands,after a while,do not show correctly,this means that the watch is under severe magnetic field, after severe shock or finally watch malfunction.
You must know that on this type of watches analog time follows digital time.
same problem here.. everytime i adjust the analog clock it moved but the digital clock dont so it means i can correct the analog but i cant correct the digital clock please help us..
The hands are driven by the digital. It seems to me you have the wrong digital city. Please review the setting instructions for your Skyhawk at: http://www.citizenwatch.com/
Press and hold the "Mode" button on the right side of your Arnette digital watch for three seconds to change the watch's mode. Press and hold the "Mode" button repeatedly until flashing digits indicate that you have entered the watch's time-setting screen.
Use the top and bottom buttons on the left side of your Arnette digital watch to increase and decrease number values as desired.
Press and hold the "Mode" button repeatedly to exit the time-setting screen and return the watch to time-telling mode.
Set Analog Watch
Pull out the watch crown on the right side of your Arnette analog watch.
Turn the watch crown clockwise to adjust the hands of your Arnette analog watch to the appropriate time.
Push the watch crown back in when you are finished setting the time on your Arnette analog watch.
The digital timepiece on a watch is set using the function buttons on the outer part of the watch face. To set the digital time, press and hold the upper left button until the seconds starts blinking. Press the lower right button to reset the seconds to "00."
Push the lower left button to move to the Daylight Savings Time portion of the watch. Use the lower right button to toggle between "On" and "OFF."
Press the lower left button twice. The hours unit will start blinking. To advance the hour, press the lower right button repeatedly until the correct hour is displayed. If you need to move the hours unit backwards, press the middle right button until the correct hour is displayed. When the hour is set, press the lower left button to switch to minutes, and use the same commands to change the minutes unit.
After the time is set, press the upper left button to exit the digital time setting function.
Setting Analog Time
You may find after setting the digital timepiece that the analog display does not match. When this occurs, you need to set the analog time. To set the analog time, press the lower left button 6 times. Next, press and hold the upper left button until the digital time starts to blink. This indicates that you are in analog time setting mode.
Analog time adjustment is completed using the lower right button. Every time you press the button, the analog time will advance 20 seconds. If you need to make a big change to the analog time, press and hold the lower right button to make the hands move faster. Once the analog time is set, press the upper left button to exit the analog time setting mode.
mcdevito75 here, Most likely the digital part of your watch is for thetime in your time zone while the analog (hands) time is for a different time zone, (Lodon / New York) visit a small watch repair shop in your area for details.
You must set the "Zero" position for your watch. Follow the instructions at this address and your problem should be corrected. http://www.geocities.com/watch_crazy/skyhawk/setting/setting.htm
