I have a Samsung CLX-3160FN and after every page it prints a message pops up that there is a paper jam 2 in the back of the printer. There is no paper jam; I open and close the door and it will print 1 page and then the same message pops up. How can I fix this?
Check paper setting paper over 80g should be set to thick.
it is most likely that the fuser actuater arm is not sitting back to the sensor properly. open the back door you will be able to see the fuser, on your right hand side you should be able to see a fliper that sit in between a sensor. try to adjust the fliper flag and see if it works.
if it still continue to give you the same error. try remove the fuser four screw 2 side on each. adjust the flag again and fix it back. it should work and double check for any lose small pices of paper jam in the printer.
