Error
Code: 32004
Please
check the following:
If you are still unable to connect, and have waited a few hours,
please try the following:
How are you attempting to connect your Wii console online?
Wireless Router:
Nintendo Wi-Fi USB
Connector
*While Nintendo provides this information for our
consumers' use, it is up to each consumer to determine what security
needs they have for their own networks, and to decide how best to
configure their network settings to meet those needs.
"Trusted" Applications:
If your firewall or PC security program keeps a list of trusted
applications
(also known as a "trusted zone"), the following programs are installed
with
the Nintendo Wi-Fi USB Connector, and require internet communications.
If prompted
by your firewall or PC security program, add these to the list of
trusted applications.
This information may also apply to certain computer security
applications,
such as anti-virus, anti-spyware, etc.:
Please check the following:
Power on your Wii
console and press the A Button on the Wii Remote to reach the Wii main menu.
Use the Wii Remote to select the "Wii" button.
Now, select
"Wii Settings" to access the "Wii System Settings" menu.
Using the arrow on
the right side of the screen, scroll to page two and select
"Internet."
Select
"Connection 1: None"
(Don't see
"None" in Connection 1? Click the Connection 1 button, then choose
"Clear Settings.")
Click on
"Wireless Connection" and then "Search for an Access
Point."
(Are you using a
wired Internet connection to your Wii console?
Select
"OK" and the Wii will display all the wireless networks it finds.
Select the wireless
network that is yours.
If you are prompted
to "Enter the Password or Key," then the wireless network you are
trying to connect to has wireless security turned on. You will need to type in
your security key or password and select "OK."
Select
"OK," "Save Settings," and then "Yes."
The Wii console will
run a connection test with your wireless network when the test is completed.
You should see the following screen:
As long as you see
"The connection test was successful," the "Wii Support
Code" does not matter and can be ignored
The connection test
was successful - Then you're almost done! After your connection test, the Wii
console will check if there is a new Wii System Update available. Once you
select "Yes" and "I Accept," the Wii will begin to download
any available updates. Click here to find out what's next!
The connection test
was not successful - If the test was not successful, you will receive an error
code.
Error Code 51330 or
52130: This means the security code you entered into the Wii is not the same
one your router is set to. Look in your router's settings and try again.
As a last resort...
1. reset your router or 2. temporarily remove the password from your router...
this way you will know where the problems lies.
Thanks
If you need further help, reach me via phone at https://www.6ya.com/expert/eric_5b00a5ceab1c0cd2
