Hi the best way to prolong the life of battery and the time it lasts is to let the battery go totally flat at least once a month and i mean totally flat so the phone dont even try to come on then do full charge but leave the phone charging for couple of hours after it says full charge.
The problem is say when you brought the phone you didnt do full charge then this causes this problem depending on how long the battery hasnt been charged for then the power in the battery is never going to get to full compacity.
So try letting the battery go totally flat then wait an hour or so and then try switching on it might light up after an hour or so keep repeating this process untill its totally flat then do full charge this should then give you longer battery life and will also keep the battery working longer before replacing.
Let me know if you need further assistance ok
I think you must check your charger and if ok replace your battery
