Re: Endura 30 Freshwater Transom Mount Trolling Motor: I...
Probably an endura 50 would be a better fit for a potoon boat. assuming the boat is normal size. if its a smaller one then this motor might work just fine. give it a try and see if it moves you about fast enough for your taste.
There is kind of a collar on the lower side of the head where the head connects to the shaft. There is a single bolt that runs right thru the shaft at this location, remove it. Rotate the head 180 degrees and re-install the bolt. 5 minute job.
