Bypass the starter switch with heavy wire. Go from positive battery terminal to starter post to see if starter is OK, if it is check wiring. Make sure key in ON position to test, bike in Neutral. You'll know right away if starter is OK. More than likely it is the starter switch button on the handlebar. I don't know anything about the security systems, but lets' hope it is not that.
SOURCE: Replace battery on my dyna super glide but it
This may be to easy ,, but check and make sure the kill switch isn't on.
