Panasonic Lumix DMC-LZ5 Digital Camera Logo
A
Anonymous Posted on May 15, 2010
When I acquire pictures from SD card, it acquires
I have a Panasonic DMC-LZ5 digital camera. When I acquire pictures from sd card to pc it acquires all the pictures previously on the card. I only want the pictures I just took to be acquired. How do I get only the new pictures to be acquired to pc and not the old ones?
Level 3:
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
  • Panasonic Master 102,366 Answers
  • Posted on May 17, 2010
Panasonic Master
Level 3:
One Above All:
Top Expert:
Answers
102366
Questions
0
Helped
10432107
Points
622693
You shouldn't be leaving the old pictures on the card. That's a guaranteed way to get into trouble. After downloading your pictures, format the card in the camera.
If you want to transfer just the new pictures, you'll have to select those pictures for transfer. Since you declined to specify what software you're using, I can't tell you precisely how to do that.
Dmc ls80 transfer
Most cameras don't have enough internal memory to take more than 1 or 2 pictures internally. Picture transfer is normally accomplished via usb cord. The process begins when you plug in your usb and power on the camera. You have to navigate between internal memory and SD card in windows explorer.
Memory card protected
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
What size memory card can i use in my lumix dmc-lz5
Although it's not the newest device out there, an SD card of 4gb would be more then suitable for it, check the manual for more info about the limitations which your device has:
Panasonic DMC LZ5 Manual
1helpful
Lz5 card does not work
Make sure you're using an SD card, 2GB and smaller. The DMC-LZ5 will not work with higher-capacity SDHC cards.
What is max size memory card for lumix dmc lz5
The only way is to use a separate card reader. When it opens on your computer, select the new pics and drag and drop them where you want them.
When i take a picture with panasonic luminx dmc-fx50 it says write erro check card
It seems that your SD card is corrupt. I had similar problem, that was resolved when using another SD card.
I am unable to un-protect the memory card on my panasonic DMC=LZ5 camera. The same card had been in the camera and in use and suddenly it became protected. How do I get it back to normal (unprotected)?
The manual for Panasonic DMCLZ5 [ date: 20060223 ]
http://dlc.panasonic-europe-service.com/EUDocs/GetDoc.aspx?did=140225&fmt=PDF&lang=en&src=3&uilang=nl-NL&model=DMCLZ5
When you are using a
SD Memory Card
•On this unit, you can use SD Memory
Cards of the following capacity (from 8 MB
to 2 GB).
The SD Memory
Card is equipped with a Write-Protect
switch E that can inhibit writing and
formatting a card. (When the switch is slid
to the [LOCK] side, it is not possible to
write or delete data on the card and
format it. When the switch is unlocked,
these functions become available.)
Panasonic Lumix DMC FZ20
Had to take my SD card in for a system recovery.
Thanks
Where does Lumix® digital camera store the pictures I take?
Unlike 35mm cameras that store images on film, Lumix® Digital Cameras store images on SD Memory Cards, which make sharing and storing your pictures easy and convenient. You simply insert an SD Memory Card into the camera, take pictures until the card is full, and then you can transfer the pictures onto a compatible PC. Once you saved all your pictures, you can erase the card and start all over again.
Top Panasonic Cameras Experts
ZJ Limited
ZJ Limited
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
