Question about ASUS Eee 4G Notebook
Change Windows XP language from Chinese to English
My friend gave me an Eee PC 4G with Windows XP home edition. But it is in Chinese. How do I change the language to English? Pls help.
  • 14 more comments
  • Anonymous Jun 17, 2008
    hi my friend from japan brought asus eeepc 4g with her everything is in japanese . where to get an english manual?
  • njihiltine Jun 24, 2008
    I will like to know how a pc language can be changed from one language to the desised one,I was told this can only be done by changing the entire windows is that true?.
  • Anonymous Jun 25, 2008
    how to change language chinese to english. i can't understand chinese language.plese.............
  • Anonymous Aug 01, 2008
    I just got window xp with chinese version
    but i can't understand chinese and i can do the language part because the selection is only chinese.
    please help me!!
  • mazzen Oct 01, 2008
    same problem but the orginal language of my windows xp is arabic and i would like to cghange it to arabic
  • sehsona Oct 12, 2008
    i have it in Arabic and i wanna change it into english
    What do i do?
  • sarmad31 Nov 11, 2008
    i want to change the language from chinese to english on my laptop it is windows xp .in need step by step instruction because i cant read chinese.
  • Anonymous Nov 28, 2008
    a friend gave me a pc but the language is set to chinese and i cant read it
    i need step by step intsructions to change it to english
  • iceman1986 Nov 28, 2008
    a friend gave me a pc with windows xp and the language is set to chinses and i cant read it to change it back to english
    step by step needed
  • Anonymous Dec 04, 2008
    i have a windows xp dont know the kind and i cant change it to english cause if i try everythin is in chinese
  • steabbott187 Jan 11, 2009
    I NEED TOCHANGE LANGUAGE FROM CHINESE TO ENGLISH
  • dost_ rasel Feb 25, 2009
    translate this sentence to english "
    边哭边看新的书最近的感觉呢别提了"
  • mohd_arif117 Mar 23, 2009
    I will write in English but i need in Chaineese
  • Anonymous Apr 23, 2009
    same
  • bijatun May 11, 2010
    Solution link . . . www.Laptop-Problem-Sollution.com
  • Anonymous Mar 22, 2014
    Change was made to foreign language by itself
    President:
  • 1,950 Answers
If the menus are all in Chinese then you will need to install an Enlgish version of Windows XP.
Posted on Mar 31, 2008
Use Windows Help & support; Go to Control Panel and select 'Regional Languages' follow the prompts from there.
Posted on Jul 04, 2008
  • mathewng41 Aug 21, 2010
    its a in chinese ,plus its old and this is beat up computer but fast .When I click on the green button on the corner you can't type the (control panel) cause there is no bar there (cause its old)
Well guys the problem is 222222222 big for the new ones but indeed very easy to solve .solution...
ok go the the computer market and ask for the multilingual interface cd.in such cd u may change languages to other languages.well the process is simple just go to regional setting in control panel and in each tabe change ur language to the desired one .computer will ask for the files to be copied then insert ur multilingual cd in cd rom and click ok to install the files.another method is auto run in this method u will select ur desired language in the popup and then click ok to install.after installation do the same things which has been described in the first method.be happy u go it.
Posted on Nov 17, 2008
Go **** your wife
Posted on Jan 14, 2010
Hi Binox,
If you can get to control panel, there should be a box that should be Regional and Language settings, if you can find it, you should be able to change everything to english
hope this helped
Posted on Jan 21, 2009
Look through the options on an English language PC if that helps
Use babelfish or similar to find the language you need, and then change the 'regional and language settings' to that language. This is 'English' in Chinese:
英语
Posted on Nov 03, 2008
Seriously?! seriously?!
Posted on Nov 02, 2008
How to change language in asus to arabic
Posted on Oct 25, 2008
You have to reinstall XP and in setup change to English in regional settings.
Posted on Sep 29, 2008
I've just installed an Epson TX200 Stylus printer and when I request to print a the print window comes up and it's in Chinese!! I have put the installation disc in 3 times and clicked on english. I'm sure it's a simple problem to solve but hey I'm blonde!
Dickinee
Posted on Nov 14, 2008
2 Suggested Answers
SOURCE:
  • 256 Answers
SOURCE: Change Windows XP language from Chinese to English
Go to http://www.asus.com then select "Services" and click "Support". In the next window, click "Download". In the next window select "Product, Series & Models" in the selector boxes and click "Search". In the next window, select your Operating System. In the next window, click the Plus(+) sign next to manuals and scroll to the English Manual. When you read it, go to "System Recovery" if the left column and click. in the right column, You will see you need a USB external DVD drive. Reading further will tell you how to install the OS. If the system will allow you to change the language, it will be when you install a new OS.
Posted on May 31, 2009
How to change windows XP from chinese to english
to change your language just go the control panel and choose region and language option and in this option you see keyboard and languages and then change your language;;;;;
Aug 17, 2010 | ASUS Eee 4G Notebook
Eee pc 4G with windows xp, its in chinese. how do i change the language to english, is it possible without downloading another version of windows xp
Start button, control panel, language, change it and region to USA,
English.
If it is a Chinese install, the only way you can change it is if windows
is Pro, or ultimate. Home editions can not load language packs.
Feb 08, 2010 | ASUS Eee 4G Notebook
I wish to change the language from french to on my ASUSEss PC900
You need to to windows update and choose custom updates. French will be one of the selections it may ask you for your Windows CD.
Dec 30, 2009 | ASUS Eee 900 Notebook
My laptop has xp windows but everything is writen in chinese how can i change it to english
Open control panel option then regional and language option change location United state ( english) again same change in location also in Language.
I hope that this has been very helpful for you
Dec 06, 2009 | ASUS Eee 4G Notebook
HOW DO I CHANGE MY WINDOWS XP BACK TO ENGLISH
my friend i have some link here that might help you understand your problem and eventually answer your problem. Click Here
But if it doesn't work the only way you can change the language from Russian to English is by reinstalling the Operating System in English version. In that way, you can change  and reset the language from Russian to English.
Hope this solution helps your problem. If you need more assistance just reply to this post. thanks
Jun 26, 2009 | ASUS Eee 4G Notebook
Change language
g o to start menu then open regional and language option there.
Then sleect your language and region .
Jun 22, 2009 | ASUS Eee PC 1000H Laptop
Change Windows XP language from Hebrew to English
you must go into control panel, click on REGIONAL AND LANGUAGES, then click on the languages tab. make sure to install the US/English language, and make it default languagethen reboot computer.
Jun 02, 2009 | ASUS Eee 4G Notebook
May 30, 2009 | ASUS Eee 4G Notebook
ASUS Eee 4G Notebook Logo
56,406 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Thomas F. Schneider
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
