Question about Grundfos MQ3-45 1 HP Pressure Booster Pump
When I turn on the tap, the water does not come right away
  • mbudd May 18, 2010
    The type of booster pump we have used does not require a tank. It senses either a pressure drop or flow to activate the pump and holds the pressure steady until the demand is gone. I failed to mention that the pump is pushing water about 300 feet to the house and also has to achieve about a 20' head. I talk with Grunfos and they think that perhaps the long pipe to the house acts like a tank in and of itself and so when a toilet is flushed there is not enough movement of water in the pipe to activate the pump. I am still puzzled as to why the water is not right at the tap when I turn it on though - is it back draining some how? Grunfos has recommended that I install another pump to bring the water into a holding tank in the house and then use the booster pump to supply pressure for the house. Your thoughts on this? Thanks
  • mbudd May 19, 2010
    Thanks for the insight - I never thought about moving that mass of water in order to activate the pump. No wonder it doesnt work properly. What we are planning is a non pressurized water storage in the house which will feed a whole house booster pump to supply adequate pressure. The holding tank will have a float and be filled from the pump in the pump house - two pumps in total...but I dont have a lot of choice as I really like the idea of constant pressure as provided by the Grunfos booster pump vs a bladder tank and fluctuating water pressure.
    Again, thanks for all you help
    Mike
  • 843 Answers
Sounds like the pressure tank isn't working right. The pressure tank should have air in it that is compressed by the water, so that when you open the tap, the air pressure should immediately begin pushing the water. Water is virtually incompressible, so you need that air to give you some volume to be compressed. After the air pushes the water for a moment, the pressure drops enough so that the pump kicks in to maintain and restore that pressure. If you don't have such a tank, that's the problem. If you do have such a tank, then it may be full of water and you will have to find a way to fill it with air. Or, perhaps the tank is not piped correctly. I hope you found this helpful. Good luck.
Posted on May 17, 2010
  • Al Kupchella
    Al Kupchella May 18, 2010
    I'm very puzzled by the two-thumbs rating. Give me some more information and I can probably help.
    Al K
  • Al Kupchella
    That's a very different scenario from what I was left to imagine. I agree that the long pipe will act like a tank, as pipe will stretch a little under pressure. But unlike a tank, unless that pipe has a pretty large diameter your tap can't respond until all of the water in the pipe starts moving - that's a lot of mass to accelerate. Putting an air bladder tank at the house would definitely help the response at the tap. Maybe that's what you meant by "holding tank". Good luck.
    Al K
SOURCE:
How do i turn off hot water supply from this boiler, need to change bath hot tap valve
You turn off the mains water valve (usually under kitchen sink) so no more water enters the property. Then you run all the taps to drain the system. When you've finished just turn the mains back on. Or if you have a modern bathroom most water inlets / pipes to the taps have their own isolator value so you just need to turn that off.
Nov 23, 2017 | Water Water Heaters
H! Can someone tell me if a 2005 Kia 2itre has a `block heater and if yes wher is it located.. thanks for your help!!
unclip the heter pipe on both inlet and outlet connect a water pipe to it and turn on the tap if water comes out right away its fine just check the thermostat just to be on the safe side make sure it working ok
Jan 22, 2015 | Kia Cars & Trucks
All taps connected to my Rinnai XR20 run only luke warm when first turned to their hottest setting. In order to get truly hot water, I need to turn the temperature lever back and forth, from hot to cold,...
Hi, try turning up your temp setting in your rinnai. Also , it may take a few seconds to get hot water if the tap is quite a way from the hwc.
Sep 25, 2013 | Water Heaters
The burner on the heater is working bu can't get water to stay hot at the faucets or showers water turns cold right away. whats the problem?
Test for crossover, where bad faucet cartridge or recirculation check valve keeps hot from reaching taps
http://waterheatertimer.org/Crossover.html
Add a comment and say what you find
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Feb 28, 2013 | Rheem Water Heaters
How do i refill ny worcester junior 24i combi boiler? as i cannot get the pilot light to light
Two types dependent on age
Early - in the mains water inlet pipe there should be a service valve/tap which when turned on will refill [it is close to or part of the fill loop - a metal braided flexible pipe
Later - underneath there is a hole for a plastic tap [supplied with boiler] to be inserted [usually just right of center] Insert and turn 90 degrees then close to it another small knob or 2nd tap which when turned [same action as a basin tap] will refill. If the first tap is not inserted properly water will drip out past its seals
For both Refill to about 1.5 - 2 bar and turn off
For the later as above but also remove the 1st tap
Mar 14, 2010 | Water Heaters
Plumbing makes loud intermitant knocking noise.
Does this happen when yo turn of the water from the tap or shower, right when you turn it off? If so, that is called 'water hammer'and is caused by too high water pressure. It's shaking the pipes when you suddenly shut it off. Turn the water of 'slowly' and see what happens, it goes away.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Nov 08, 2009 | Kuppersbusch 24 in. IG6344 Built-In...
Slow drain of water from toilet tank!
Turn off the water when it is full and put a drop or two of food coloring in the tank. Sit back and watch and you'll find where the water is going and hopefully that will help you solve the problem. Could be any number of things
Jul 25, 2009 | Siemens SpeedStream 4200 (13A4200001)...
My machine will not fill with water.
It sounds like the switch that controls the water level is stuck ,thereby telling the controller that it is already full of water, causing it to start agitating right away.
Give the top of the console panel a good tap, this may release the switch if it is stuck.
If this does not work, then possibly the pressure hose is blocked that controls the switch.
Plz rate my solution.
Thanks.
Jan 02, 2009 | GE WBSR3140DW Top Load Washer
Re pressurise the BAXI DUO TEC COMBI 28 HE A
I represurised mine by the following:
1. unscrew the left hand circular tap all the way
2. slowly unscrew the right hand circular tap untill you hear the water coming through.
3. turn off both taps when pressure is good
Dec 28, 2008 | Kitchen Appliances - Others
Nothing in instruction about water tap
Yes you need to turn the tap on and leave it on. Otherwise you will burn out the pump.
May 22, 2008 | Danby 22 in. DDW396 Free-standing...
Grundfos MQ3-45  1 HP Pressure Booster Pump  Logo
978 people viewed this question
Top Grundfos Garden Experts
john h
Audrey Messer
Audrey Messer
Jay Finke
Jay Finke
Are you a Grundfos Garden Expert? Answer questions, earn points and help others
