I just installed a new AO smith century two speed pump 1081. I keep tripping the breaker and think I may have wired the pump incorrectly. The pump has line 1, 2, 3 or 4 and has two black and yellow leads going to the line 3 or 4 position from the hi/low toggle switch. I currently have the red wire going to line 1, the white to line 2 and black to line 3 or 4.
The red and black wires if ran correctly are the load lines(power). The white is neutral or ground. If its a 1/2 to1-1/2 hp motor connect the red and black wires to terminals #1 and #4. If its 2 hp use #1 and #4. If its 3 hp use #2 and #4. Connect the white wire to the green colored screw. A grounding conductor should always be connected under the green grounding screw, which is located within the terminal compartment of the motor. You can check the breaker for the wire colors, one should be black and the other red. The white wire should be terminated to the neutral/ground bar in the can.
