Radio Communications Logo
Posted on Mar 31, 2008
CANNOT PAIR AOEM BLUETOOTH HEADSET TO LG SHINE KE970 MOBILE PHONE
I AM UNABLE TO PAIR MY NEW AOEM GW-BT-002 HEADSET TO MY MOBILE PHONE LG SHINE KE970
  • 1 more comment
  • Koukla mou Oct 03, 2008
    THANK YOU SO MUCH FOR YOUR ASSISTANCE, IT WORKS!!!!!!!!!
  • Anonymous Feb 28, 2009
    DONT KNOW HOW TO PAIR
  • Anonymous Mar 31, 2009
    I was given an AOEM GW-BT-002 with no instructions. After hours of frustration trying to pair it with my phone, I found and followed Louber 2409 instructions. Bingo! Worked first try. Thank you Louber
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Jul 13, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
2940
Points
39
Push and hold both vol(+) and vol (-) at the same time for approx 2 secs. The headset will falsh green and red lights. Get your phone to search for bluetooth devices. It should find the headset. Enter pairing code 1234 in phone. Done
A
Anonymous
All Bluetooth headsets are meant to be compatible... but i recently purchased an LG KG290 .. to which i have tried pairing 2 Bluetooth headsets i own but NO luck ..
LG mobiles are Pre set on Bluetooth and will only accept compatible Bluetooth head sets which are Pre set for a certain model of LG mobile .. if your model of LG isn't listed in the compatible list then your LG will not connect to the headset ... The same also applies when buying a Bluetooth Dongle
Hope this helps
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Aug 25, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
2164
Points
I can not pair my advanced design bluetooth handsfree headset to my lg shine
Anonymous
Level 1:
  • Posted on Jul 06, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
2164
Points
I have a lg shine phone that i need to pair??? How do i get started???
1 Related Answer
Anonymous
  • Posted on Aug 26, 2008
SOURCE: CANNOT PAIR AOEM BLUETOOTH HEADSET TO LG SHINE KE970 MOBILE PHONE
The mamual says to hold the - and + volume keys at the same time for approx. 2 seconds till the light starts to flash green and red. The pairing code is 1234
1helpful
Lost My pin for the bluetooth AOEM GW-BT-002 headset. the generic 0000 pin does not work and neighter does the 8888
Hi johan56s The pin is 1234. Hope this helps ???
My problem is,that i can make a call using my ear piece,but not sure on how to receive a call via ear piece.If i just answear via Mobile, can only hear through phone.Wish i didn't mislay my handbooks. Hope someone can help. Cheers Waveslider123
Pairing Problem - BluetoohJabra VBT2050 & LG Shine CU720
I have a Jabra VBT 2050 bluetooth headset. As per the product user manual(page 8) this device is compatible with any bluetooth mobile phones with bluetooth version 1.1 or higher.
My LG Shine CU720 mobile phone is not able to detect the VBT 2050 device. I checked the specification of mobile phone & its bluetooth 1.2. I am able to pair the VBT 2050 with other bluetooth mobile devices.
Could you help me resolve my problem. Appreciate quick help
LG VU does not recognize my blue tooth while trying to pair two
Help my pair my bluetooth with my LG shine phone. I have a jawbone bluetooth.
2helpful
Pairing with Nokia N95
hi,
I posted the manual to this headset here
http://www.fixya.com/support/t526500-cannot_pair_aoem_bluetooth_headset_lg
2helpful
2answers
Power up
follow the steps below:
• Setting the headset into pairing mode
1) Ensure the headset is fully charged
2) The headset must be switch off
3) Press and hold the on button for +- 8 seconds until the light flashes red-blue
4) The headset is now in pairing mode
• Searching for the headset on the phone
1) Go to “settings” or “connections”
2) Select Bluetooth, then options
3) Select Devices and click add
4) The phone should search for any available Bluetooth devices and display what was found
5) Select the AOEM device and click add
6) You will be required to enter in a pass code which is standard ‘0000’
7) If successful then the headset will start flashing BLUE every few seconds.
8) If it’s a Samsung or Nokia phone you will need to “AUTHORIZE” headset on the device.
• The headset is now paired with the phone
Hope this helps
Season's Greetings from Fixya!
Chris (ziraffa)
2helpful
My LG Shine KE970 can not find Motorolla H700 bluetooth headset
Is the question really, is your H700 in pair mode? To set this you need to push and hold the big talk button while the boom is closed. once the purple light comes on open the boom to keep the light. Now you can search for it with your cell phone.
Hope this helps and don't forget to rate :)
88helpful
12answers
8helpful
3answers
Bluetooth to mobile pairing
98helpful
9answers
New bluetooth earpiece, no instructions
Push and hold both vol(+) and vol (-) at the same time for approx 2 secs. The headset will falsh green and red lights. Get your phone to search for bluetooth devices. It should find the headset. Enter pairing code 1234 in phone. Done.
Top OEM Systems Radio Communications Experts
eradiostore
eradiostore
 Grubhead
Grubhead
Are you an OEM Systems Radio Communication Expert? Answer questions, earn points and help others
