How do i wir a mtx 251d at a 2 ohm load
SOURCE: how do i wire a mtx 251d at a 2 ohm load
To wire up a 2 ohm load depends on the subs. You will either need 1 sub rated at 2 ohms or 2 subs at 4 ohms wired in parallel. This website will help.
http://www.the12volt.com/caraudio/woofer_configurations.asp?Q=2&I=41#results
You can also use 1 dual voice coil sub rated at 4 ohms wiring the same way you would the 2subs at 4 ohms. Good Luck
