I'm a retired handicapped vet that wants to learn electric scooter repair. I'm good with my hands and could use some extra money. Where can I learn aboout these scooters in Austin tx. Thanks Frank
Re: I want to learn electric mobility scooter repair.
Hi Frank. It helps to have an electrical background and access to parts and fault codes etc. Our website has some common faults and solutions
.www.scooter-works.co.nz
Good luck. Neil.
hi yes code 8 is a controller error try ringing a pride spare parts to c if they have reco ones .....very expensive new ones try monster scooter parts ...good luck
hi, must likely it's the connectors located between the axle and frame,, depending on model, some are pins, the older one are contacts, convince your self there is a good connection here. cleaning gently ...
krazy the brake will have to be replaced contact the provider where you got the scooter to ask if they can repair it. If not you can contact Repair Xpress @ 1-877-581-3733 to see if they have a tech in your area Hope this helps
Hey there Frank. Let me begin by thanking you for your sacrifice. We are the land of the free because of the brave. THANK YOU. My son is a disabled veteran of the Iraq war so I know something about this. Here is an interesting link that may get you on the right path
http://www.thewheelchairsite.com/blogs/wheelchair_repair/archive/2006/10/25/98262.aspx
Take care and good luck Frank. Joe [former Armor Company Commander]
hi, if it's the one handed operated control, Fiirst check the connection that go fro mthe control to the scooter and make sure it a tight connection if that and the lead appears ok then sadly you will need to get the hand control repaired, please don't take it apart, disconnect it from the scooter and take it to a repair agent.
Rascal's are made by Electric mobility and are based in Dorset in the UK. Web link http://www.electricmobility.co.uk/Default.aspx Go to their sit to download manuals and get information.
Jazzy's are made by Pride mobility based in Oxfordshire in the UK. Web link http://www.pride-mobility.co.uk/ click on Resource Center at the top of the page.
